How do I attach a body to a sketch point?
- 3d_model_guy
How do I attach a body (a small sphere) to a sketch point?
I can create a datum plane of the larger body's surface, I then select the small sphere, in attachment mode, I can select the datum plane for Place Face, I can also select the vertex of the sketch, however, the sketch point does not appear in the sketch.
The final goal is to have the small sphere on the center of the rectangular shape on that datum plane, exactly where the sketch point is.
However, a more generic question is how do I attach any object to any points on a sketch?
Here's the freecad file:
- Capture2.JPG (101.6 KiB) Viewed 1062 times
- Capture1.JPG (54.73 KiB) Viewed 1062 times
Re: How do I attach a body to a sketch point?
That point is only visibl outside the sketch if you toggle it from construction to real geometry with Sketcher ToggleConstruction.
- 3d_model_guy
I changed the single point from construction geometry to normal geometry, it is still not showing.
Works for me in the file you provided....
- Annotation 2022-05-25 111941.jpg (29.16 KiB) Viewed 912 times
- Socquette_SHALM.FCStd
- (26 KiB) Downloaded 11 times
- 3d_model_guy
In Sketch, there's a center point called "Sketch.Vertex9", try attaching the small sphere on Vertex9, it doesn't work for me, nor is it visible outside of the sketch.
- 3.JPG (103.47 KiB) Viewed 855 times
In the file you provided the point is not centred, however it does work.
- 3d_model_guy
Interesting, it isn't visible to me nor can I attach to it.
What version is your software?
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
You have to make it visible.....
Not like this....
Not like this....
- 3d_model_guy
ah, I lied.
With FreeCad official release 0.19.4, it worked; the point becomes visible after making it a normal point (instead of construction point).
Originally, I used FreeCad Linkstage 2022.111, and the point stays invisible after making it a normal point (i'll file a bug for that on Linkstage).
However, I noticed with 0.19.4, the reference destination for the point changed from vertex41 while inside the sketch to vertex21 while outside the sketch. Is this something worthy a ticket?
- a.JPG (101.59 KiB) Viewed 791 times
- b.JPG (103.47 KiB) Viewed 791 times
