I've been trying to use the Lattice2|Array Filter tools. I get errors if I try to use a sketch or a wire as a template to surround the desired placements. It does work if I make the wire into a face. As that the intended usage? If so, the tooltip could be more explicit about what is required.DeepSOIC wrote:
Lattice2 Array Filter Template
- arrayfiltertest.FCStd
- (12.55 KiB) Downloaded 21 times
- DeepSOIC
Re: Lattice2 Array Filter Template
made https://github.com/DeepSOIC/Lattice2/issues/67 to hopefully not forget about it. Yes, it is supposed that you make a face.
Filling in a sketch face automatically would be a user friendly enhancement.
