Help with fillet approximation math
dtay
Post by dtay »
I am trying to approximate accurate point positions on a fillet. The fillet is at the edge of a hole placed perpendicularly through a cylinder wall. In this image you can see between the quadrants around the hole there is a mismatch. The pink point does not align to the contact point of the fillet and green sphere.
I would like to know if I should look at affine rotations to correct this or if it is possible within spherical coordinates? Or is there a better approach?
Any input would be appreciated!
sphere_coord_affine_question.FCStd
(142.54 KiB) Downloaded 20 times
dtay
Re: Help with fillet approximation math
Post by dtay »
Hi again,
I made some progress on this. I ended up using quaternions and rotors:
phpBB [video]
I'm sure that the Placement API can handle arbitrary axis rotations, but I went a different route and learned some math along the way.
I used the code form this repository: https://github.com/jimijimi/rotor. And the Linkstage branch.
Just a follow up :)
edwilliams16
Post by edwilliams16 »
dtay wrote: Sun Jun 05, 2022 5:24 pm I'm sure that the Placement API can handle arbitrary axis rotations, but I went a different route and learned some math along the way.
Just a follow up :)
You are of course correct in saying that FreeCAD has an API for rotations. The function rotate( point, angle, vector ) from the above repository could be written:
point = App.Vector(1, 2, 3)
axis = App.Vector(1, 1, 1) #axis direction need not be normalized
angle = 45 #degrees
rot = App.Rotation(axis, angle)
rotatedPoint = rot.multVec(point)
Here's some material on the Rotation and Placement APIs: https://wiki.freecadweb.org/Sandbox:Edw ... #Rotations
Quaternions are the preferred implementation for rotations. You might enjoy https://www.youtube.com/watch?v=zjMuIxRvygQ and https://www.youtube.com/watch?v=d4EgbgTm0Bg by Grant Sanderson.
dtay
Post by dtay »
Hi Ed,
Thank you for the code and the links! The 3B1B linear algebra series has been very useful. Your Sandbox is a good resource as well. multVec() in particular was a bit of a blackbox for me, but your examples help a lot. It would be nice to see your API documentation integrated in to the official wiki pages.
This site was useful in understanding 4x4 matrices: http://www.codinglabs.net/article_world ... atrix.aspx
And this one for quaternions:https://www.meccanismocomplesso.org/en/ ... th-python/
I now have some 5 axis G code generated within FreeCAD:
phpBB [video]
