I have been struggling with this for a while now and can't figure out how to resolve it.
I have a .igs file that I have oped in FreeCAD, it looks like this
I select it and export as wrl to be used in KiCAD and I get this wierd thing that looks like some of the wall thickness is zero
I have tried everything I can think of, including changing the material type but nothing works.
I also got an igs file from a different manufacturer who has an alternative part and I get the same result. However I have done the same thing with other igs files with no problem.
The step file export has no problem. I have tried opening the step file to export as wrl but I get the same result.
Any help would be greatly appreciated. I just downloaded FreeCAD 0.19.4 and it has not helped.
Thank you
is it a zero thickness wall or something else
Re: is it a zero thickness wall or something else
Hi and welcome to the forum!
For better help you should attach your FreeCAD infos and you can also upload the file. It is also worth a try to use the latest development version, currently 0.20.
Thanks chrisb,
FreeCAD info is as follows:
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: English/New Zealand (en_NZ)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- thomas-neemann
can you upload the file somewhere?steve.chaplin wrote: ↑Mon May 16, 2022 1:33 am ...
Sure thing, I have uploaded a selection of igs files that are creating problems for me.
These are 2 manufacturers with 2 different types of connector, the ones I am most interested in are:
Holin_CBN-L112CPR
Holin_CBD-L108CPR
https://drive.google.com/drive/folders/ ... FF7L1cNlUf
Holin_CBN-L112CPR
Holin_CBD-L108CPR
- thomas-neemann
With this software combination it seems to work
Version: 0.20.28873 (Git) AppImage
Branch: (HEAD detached at 4366c2f)
Hash: 4366c2faecae2c5326c12bbe8cbd230ec817eb0c
Yep, it all looks ok'ish in FreeCAD, but using it in KiCAD doesn't work.
I had someone open the igs file in Fusion360, turns out that the models were made with un-stitched surfaces, in Fusion360 there is an option to stitch together a selection of surfaces into a body.
And that fixed the problem.
