How to think about a project
I am just learning FreeCAD. While I have watched quite a few videos, gone through a number of tutorial, and spent hours using the application it is still largely a mystery to me. There are so many controls! Knowing what they do, when to use them and how seems like quite a learning curve that is going to take a good long while in order to develop some proficiency.
So, I have a few basic questions concerning a project I am working on.
I’ve been using the Part Design workbench in FreeCAD 0.19-24366 on a MacBook Pro running macOS 11.5.2, Big Sur. I modeled everything on the XY Plane.
Project Description:
The project is a long, squat, irregularly shaped container about 10” long, with an open top and lid that drops onto it. The container will have end-caps on it to keep the contents from spilling out of the ends. Four parts all told: the container body, the lid, and two end caps, although the end caps and container body will be one piece when 3D printed. When printed their will be just two pieces: the container and lid.
The upper image in the screenshot attached shows the lid as well as the container but without the end caps. In the lower image you can see I have fashioned a cap to go on one of the ends of the of the container. I wanted the cap to follow the perimeter of the container along some of the container’s edges so I clicked on the side of the container pad in FreeCAD to make it yellow in order to use it as external geometry when I was sketching the cap. What I found, however, is that when the cap is padded, instead of padding from the edge of the container away from it, the two shapes overlap each other occupying the same space.
So, here you can see some of my weaknesses in terms of managing this project with more than one part. I don’t know how I should be thinking about this project in terms of being able to model the parts and control how they fit together. I have struggled, mightily, to understand the relationships between files, bodies, origins, sketches and pads, how they work with each other, controlling their visibility, copying and pasting them, moving them in relation to planes and axes, separating and combining objects, etc. I’m not asking for explanations of all those things—I am learning about all that little by little as I go.
I suppose my first questions (and I'm not really sure what I should be asking!) are about how to think about making this container, and do it so that it can be 3D printed with the two end-caps and container body as one piece of material and the lid as another.
•Since it will be a separate piece should the lid be in a separate file?
•How should I think about the heirarchy of bodies, pads and sketches for this project so I can make and position the two end caps with respect to the container body?
•How do I make the two end caps and position them so that they butt up against the container body and not have the parts overlap, or should they overlap?
I have tried for hours to puzzle these things out but being new to FreeCad and CAD in general I remain at a loss.
Thanks for your help.
[EDIT: I have just discovered I can move the end cap I made by contol-clicking on its Body and selecting Transform. I still have a question as to whether the end cap and and container body should just butt up against each other or if they should overlap each other by some amount?]
Re: How to think about a project
Hi and welcome to the forum!
If you want to print the container with the endcaps as a single solid, you should model them in a single body.
Use external references of the sketch to get the outlines of the caps.
Or model the container as a solid and subtract with a second sketch the innards
The lid can well be modeled in place by using a PartDesign ShapeBinder from the sketch in the other body, you just export and print it separately.
The extra lines at the ends don't mean that the features are not connected. You can get rid of them by setting (on the last feature) Refine=true.
Thanks much. I will have to do some research to understand fully what you mean, which is totally well and good--that's how I learn. I have not previously encountered the ShapeBinder, or Refine=True for instance. More to learn. Yay! Thanks again.
- ThingTank_SHALM.FCStd
- (29.93 KiB) Downloaded 17 times
- Capture d’écran 2022-05-15 032459.jpg (71.43 KiB) Viewed 677 times
There's a lot of useful techniques to be learned from @shalmaneser 's model above.
The main body (Body) is created from a Pad of the cross-section sketch (Sketch), followed by pocketing out the interior with Sketch001. Sketch001 imports Sketch as external geometry so that the wall thickness can be specified while remaining parametric in the Sketch dimensions. The length of the pocket is given as an expression (Pad.Length - 4 mm) again fixing the wall thickness, while being parametric in the length of the box.
To make the lid, a separate body (Body001), he makes SubShapeBinders of Sketch and Sketch001. This is required to be able to import external geometry from a different body. The lid inner and outer widths get referenced to the corresponding box widths in Sketch002 and Sketch003 via external geometry references to the ShapeBinders. Lastly the lid lengths in Pad001 and Pad are given by expressions relating them to Pad.Length of Body
I enclose a model showing some different techniques - lots of expressions, and sketches translated from primary planes, rather than attaching to faces, which can trigger the topological naming problem.
- ThingTank_EW.FCStd
- (52.04 KiB) Downloaded 12 times
@edwilliams16 : If you move bodies via Transform it breaks some function. (Binder : relative=false)
Oops. I just lifted the lid cosmetically at the last second.
Thanks so very much for your very kind assistance. I have my work cut our for me, learning about the things you mentioned.Shalmeneser wrote: ↑Sun May 15, 2022 1:28 am
(PartDesign_SubShapeBinder : Relative=False to be able to move it with Std_TransformManip)
Your explanation of @shalmaneser's model above should prove very helpful. Much appreciated. While I understand much of what you wrote it is going to take some time for me to understand it all completely. There is one question your explanation raises for me that has to do with the heirarchy of the FreeCad Model Tree that has confused me since day one. You wrote "The main body (Body) is created from a Pad..."edwilliams16 wrote: ↑Sun May 15, 2022 3:48 amThere's a lot of useful techniques to be learned from @shalmaneser 's model above.
I enclose a model showing some different techniques - lots of expressions, and sketches translated from primary planes, rather than attaching to faces, which can trigger the topological naming problem.Screen Shot 2022-05-14 at 5.47.00 PM.png
When I began learning FreeCAD at least one tutorial said that after creating a new file the first thing to do in Part Design was to create a Body. Creating a Sketch came after that, then finally a pad. I've always thought of the Sketch and Pad as belonging to the Body which was created first. You seem to suggest that the Body is created as a result of the Pad which seems to me rather the opposite of what I had understood. The whole hierarchy tree in Model View seems rather upside down to me. In my mind, if the Body comes first, then the Sketch should be shown above it, and the Pad then above that in much the same manner as one would lay a foundation of a house, then upon it the walls, followed by the roof. Or, a tree has roots that come first at the bottom (corresponding to the Body), followed by its trunk above that (Sketch) then leaves (Pad) on top. FreeCAD's Model Tree View seems upside down to the way a tree actually grows which is confusing to me. I'll just have to get used to that, I guess, but I still have the question, how was the Body in @shalmaneser's model created by the Pad?
Thanks, again.
Sloppy terminology on my part. Better would be "the main body consists of a Pad"
The hierarchy is illustrated by the dependency graph - created by Tools|Dependency graph.
Body and Body001 are containers. They have their own local coordinate systems, shown by the Origin Object. Inside them, we see what depends on what.
Consider Body001. Building upwards, we have Sketch002, attached to XZ_Plane001. It depends on External geometry from Body via Binder. Pad001 pads Sketch002, its length comes via an expression (Pocket.Length - 4 mm) from Pocket, which in turn derives from Pad.Length.
So the tree is a tree of dependency, upside down if you like. The tree depends on its branches, which depend on the leaves.
Two things we can draw from this.
- We can't have dependency loops. A depends on B which depends on C which depends on A. Calculating such a loop would never terminate. You'll see red lines in the dependency graph, and you'll get "not a DAG" errors (DAG = Directed Acyclic Graph)
- You are free to delete Pad002 as nothing depends on it. Sketch003 will remain. OTOH, if you try to delete Sketch003, FreeCAD will complain that it will break Pad002 - but will let you do it if you insist.
