I created a sketch, that becomes invisible on pad action.
I tried the pad checker, but when I let the checker remove duplicate vertices, the sketch turns into error state with redundant constraints.
Deleting all redundant constraints turns the sketch into white colored lines, which means that the sketch is not fully constraint.
Need some help. How can I get rid of the real problem and remove it?
create sketch and fc refuses to pad it
- cap01.FCStd
- (9.45 KiB) Downloaded 21 times
Re: create sketch and fc refuses to pad it
Your sketch is un-maintainably complicated. Separate the pad and pocket, use the mirror symmetry, use equality constraints rather than equal dimensions. Construct the basic shape with the multiline tool with straight lines, add the filets with the sketcher fillet tool.
- cap01_EW.FCStd
- (33.08 KiB) Downloaded 16 times
@edwilliams16 is right : un-maintainably complicated.
What is the logic ?
Some dimensions are important :
* circles radius/position
* global form
Some dimensions/constructions are for aesthetic purpose only.
Try not to mix everything !
What is the logic ?
* global form
- Annotation 2022-05-12 120933.jpg (34.9 KiB) Viewed 708 times
- cap01_SHALM.FCStd
- (28.35 KiB) Downloaded 12 times
Hi @edwilliams16,
thank you very much for your help!
The complicated creation is due to the fact that I had the blue construction elements as input conditions. As well as the fact that it is to be made from an 160mm round.
I try to do it again according your advices. Thanks!
Yes, I wanted to use mirror symmetry. I created half the sketch and tried to use mirror from sketcher - but it reported the sketch as invalid. Didn't know, that I have to close half the sketch before mirroring.Separate the pad and pocket, use the mirror symmetry, ...
Sketcher_ValidateSketch -> Highlight ... : One troublesome vertex
- Annotation 2022-05-17 092214.jpg (18.3 KiB) Viewed 554 times
