Hi, as a FEM novice tried to model a simply supported beam.
Length (span) 2900 mm, 150x50 mm on edge. (separately calculated, Ix = 14062500 mm4, Sx = 187500 mm3)
C24 Timber Wood material using average MoE E of 10.8GPa. 450 kg/m3 density (self-weight not constrained for this test)
Fixed constraints on bottom outer edges, using 0.86kN/m UDL along upper face. This UDL is converted to a point load (860 N/m * 2.9m = 2494 N) and applied as a 2494 N force constraint at midspan on upper face.
GMSH mesh (50 max mesh) and Calculix appear to function OK.
External calculations seem to give a max deflection of around 5.24mm but this FEM result shows a 2.33 mm max deflection. What am I doing wrong?
Model attached.
[solved] Deflection result in FEM on a simply supported beam
- A00260002a FEM Simple Beam.FCStd
- (891.79 KiB) Downloaded 35 times
Re: Deflection result in FEM on a simply supported beam
You should get the desired result if you replace the fixed boundary conditions with FEM ConstraintDisplacement and select just the three translations for one edge and two translations (without the axial one to simulate roller support) for the other edge.
By the way, this topic should be placed in the FEM subforum.
Thanks NewJoker. That fixed the deflection issue.
Have attached the now modified file for others to view the changes.
- A00260002b FEM Simple Beam.FCStd
- (888.72 KiB) Downloaded 35 times
Re: [solved] Deflection result in FEM on a simply supported beam
Hi sorry, I'm trying to run a similar model and I can't seem to get my desired max deflection.
Dimensions: 100 x 9 x 35mm
Ix = 32156.25 mm4
Material: Graphite
E = 11.7 MPa
Density 1750kg/m3
I actually wanted to simulate self-weight and observe the deflection but for the purpose of replicating closely to your model and using the formula 5/384 wl4/EI. I used a constraint force of 0.54N (rounded from 0.54077625)
I used an auto G-mesh (should i not?) (what is the recommended mesh max size with N-mesh?)
External calculations seem to give a max deflection of around 18.7 micrometer but this FEM result shows a 38.27 (z direction) micrometer max deflection. What am I doing wrong?
Model attached. Also, if I were to have both supports not at the ends but maybe 10mm away from both sides each, how do i go about it? I have been slicing the model at the location i want to put my supports to be at, and then putting displacement constraints at the edges of the sliced part. Is this the correct way of doing so?
Thank you.
Ix = 32156.25 mm4
Material: Graphite
E = 11.7 MPa
Density 1750kg/m3
Thank you.
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/Singapore (en_SG)
* 3D_Printing_Tools
* Manipulator 1.4.5
* MeshRemodel 1.8919.0
Hi dinodano,
Very rusty on this.
Had a quick squiz yesterday at your model and calculations. I could not see any obvious reason for observed differences - I confirm your results. I did wonder why you applied the load as a UDL constraint rather than a material of the given density and a self-weight constraint.
A few other things:
About choosing another mesh. Don't know anything about that, such matters as why one might choose a differently sized mesh or even a different mesher are well above my pay grade as a FEM novice.
About moving the supports to 10mm away from the current support positions at 100mm apart. If I've read that correctly you want to have a piece of graphite 100mm long with no immediate supports and a 10mm air-gap at each end to the supports at 120mm apart. Somehow even as a FEM novice I think that isn't going calculate. I would suspect the computer says No! Why not make your piece of graphite 120mm long to do the FEM deflection analysis?
Or did you mean 9mm width plus 2 x 10mm air-gaps to supports acting on the side faces? Can you show a sketch of what you're trying to achieve with this 10mm support increase?
One thing I remember observing in FEM was that it didn't like editing of constraints on the fly. IIRC, the only way I could get consistent results was to construct any model from scratch with correctly defined constraints. If I started to modify constraints after building a model, doing a 'what if' scenario, the numbers were not consistent.
Busy at present, but will likely revisit this in a few days, in the interim, maybe someone else could offer a solution.
And like someone suggested to my question, should your question be in the FEM section?
