that sounds good
Issue #6767- [Bug] Draft big Scale Multiplier with 2d text causes crash (was: Freecad and really big dimension)
- thomas-neemann
Re: Freecad and really big dimension
Re: Issue #6767- [Bug] Draft big Scale Multiplier with 2d text causes crash (was: Freecad and really big dimension)
issue #6767 "[Bug] Draft big Scale Multiplier with 2d text causes crash" should probably be fixed before v0.20 release.
Can you please attach a file with which the crash you see can be reproduced?m1cha1 wrote: ↑Fri Apr 15, 2022 10:42 pm I'm experimenting with Freecad and I've found some problems (problem with displaying or crashing) with big dimension
Problem with displaying-step to reproduce (Part workbench)
1. Insert Cube
2. Change dimension for example Length by adding 0 to the default size (10mm)
From 100000000 mm there are problem with displaying cube,
Here with
Version: 0.20.28840 (Git)
Hash: 936b51bbc95ea3e6d6fcee137606338438644cda
Python 3.8.6+, Qt 5.15.2, Coin 4.0.1, OCC 7.5.3
Locale: English/United States (en_US) [ OS: German/Germany (de_DE) ]
With the latest version no crash with a Part/Cube but I still have a crash with Draft/Text. In the log file I have:
Log: Draft workbench activated.
Msg: ----------------
Msg: GuiCommand: Text
Msg: Pick location point
Log: make_text
Msg: Text
Msg: string: ['HELLO']
Msg: placement: Placement [Pos=(-0.286788,0.496732,0.819152), Yaw-Pitch-Roll=(29.9999,-1.66922e-05,55)]
Err: Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Access violation
Log: The event type 12 was sent to QOpenGLWidget
Object tree:
QOpenGLWidget is child of
SIM::Coin3D::Quarter::QuarterWidget is child of
QStackedWidget is child of
Gui::View3DInventor is child of
QMdiSubWindow is child of
QWidget is child of
QMdiArea is child of
Gui::MainWindow
Version: 0.20.28872 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
+1
Also with your example you attached to the first post I cannot reproduce the crash nor anything else special.
I see that you use a special build of FreeCAD. Can you try out this build:
https://github.com/FreeCAD/FreeCAD-Bund ... /0.20beta1
Maybe then the crash goes away for you?
@m1cha1 see above
@m1cha1 ping
