cut surface
cut surface
Hi all, i need to cut a surface, i try to find tutorial and topic in the forum but nothing.
Someone can inform me the way to do this?
- test.fcstd
- (7.76 KiB) Downloaded 148 times
Re: cut surface
You don't give very much information here. But either way you want to go, I don't think your going to get the results your wanting with what you have. This is because your 2 surfaces have no thickness. Visually, it may look like they do, but that's only because you can't show "nothing", but mathematically, they are only 2 dimensional objects and you need at least the object doing the cutting to be 3 dimensional when making this type of cut.sket wrote:Hi all, i need to cut a surface, i try to find tutorial and topic in the forum but nothing.
Now, FreeCAD can cut faces when they are both on the same plane, but when they are at an angle like your example, there is a cut made, but you do not get the result you might hope for.
Mark
This post made with 0.0% Micro$oft products - GOT LINUX?
Re: cut surface
Part WB boolean operations can sometimes work in simple cases with surfaces, but you very quickly get failures when things start to get at all complicated. You can use a 3d shape (e.g. a Part Cube) for a tool to cut a Part Plane. But your curved faces will not work even if I modify your tool sketch to make the tool a 3d block rather than just a face.
However as Mark said, if you can first make both these faces into 3d solids then the Part cut will work.
There has at times been some talk of writing a surfaces WB for FreeCAD but nothing has come of that yet.
So if the end result of why you are modelling this surface is to make a solid, then make the solid first and probably use 3d solid tools and the Part wb cut.
Jim
Jim
Re: cut surface
Another round about way to get the result that would probably work is
change you sketches to closed profiles, so that you have two 3d solids and not surfaces
then do the boolean cut in the Part WB
then change to the Draft Workbench, and select "downgrade" on the result of the above
then select all the downgraded faces that you don't want and delete or hide them, ....you would then be just left with the surface you asked for..
Jim
Jim
Re: cut surface
another way:
1: make a fusion of the two objects
2: select the needed face and enter this command to duplicate it:
Part.show(Gui.Selection.getSelectionEx()[0].SubObjects[0])
Re: cut surface
Guys, have you noticed that sket used Part Design Pads to create the surfaces? sket must use 0.13.1828. Just try to edit one of the pads, it will throw an error.
sket: the purpose of the Part Design workbench is to create solids. Making surfaces is not allowed anymore in the current v0.14 development version which is almost ready to be released as the new stable. To extrude surfaces you should use Part Extrude.
A surface trim tool sure would be nice.
An alternative way at the moment would be to use the Part Section tool to create an intersection edge on the upright surface, then use Shape Builder to create vertical edges then make a face of this.
looo, your solution is good as well and less of a hassle. Though it's a pity that all these alternatives don't create a parametric surface.
- FC_Section_of_2_surfaces.png (26.51 KiB) Viewed 8824 times
Re: cut surface
I assumed that the vertical surface is wanted to be cut off at the horizontal surface so that all the material of the vertical surface that protrudes above the horizontal surface is removed? Is that what you are trying to achieve?
I had previously tried simple copies and they did not work, however after Norm's post I thought I would try Part Extrusions from the sketches. It works if you change the horizontal sketch so that it is a profile for a solid that fully encloses all the material to be removed from the vertical surface, and then Part extrude both sketches and use a cut.
like this You would save a lot of confusion if you would post your Help about FreeCAD data.....when you first post a question.
Like this
OS: Ubuntu 12.04.4 LTS
Platform: 64-bit
Version: 0.14.3638 (Git)
Hash: 940f7e69ba0a0d1c34a910b58ef96f4e551fda07
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.1
Like this
Platform: 64-bit
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.1
Re: cut surface
thanks guys for all the suggestion, but i've tried many and many ways (pad or extrude) to achieve the part that i want and nothing.
now i begin the project with another cad, i think to draw what i want but it will be not refine as i hope to do with freecad.
when i finish show here the result and to understand if possible to create with freecad.
thanks.
thanks.
Re: cut surface
Would this be a good candidate for a feature request in Mantis?normandc wrote:A surface trim tool sure would be nice.
Re: cut surface
Absolutely!
But jriegel may prefer to wait for a Surface Design workbench, which he's mentioned as planned.
Still, it doesn't hurt to put it on Mantis.
