Hi everyone,
this is my first post, I hope to do it correctly.
Problem: I have a model with some colored elements. When I export the model as a STEP file, the color disappears and the entire model is default gray.
I have already read the related posts:
https://forum.freecadweb.org/viewtopic.php?t=44126
https://forum.freecadweb.org/viewtopic.php?t=50131
and I have set the STEP settings as suggested but the problem stays.
FreeCAD version:
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
I attach here my project and step files.
Thank you very much in advance.
Issue #6451 - Exporting STEP loses color
- Cap_1000uF_160V-Part.step
- (97.57 KiB) Downloaded 29 times
- Cap_1000uF_160V.FCStd
- (103.42 KiB) Downloaded 20 times
Re: Exporting STEP loses color (2)
Can you test on FreeCAD development build?
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Thank you Kunda1 for your fast response.Kunda1 wrote: ↑Thu Feb 24, 2022 4:04 pm Can you test on FreeCAD development build?
As requested, tried on:
Version: 0.20.27422 (Git)
Hash: d938733eaf2c2ce7cb18d1cbb56147185c473530
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Unfortunately, the problem stays anyway.
The problem seems related to the use of a PartDesign Body. If you replace it with a Part SimpleCopy the applied face colors are exported to the STEP file.
- Cap_1000uF_160V_2.FCStd
- (119.92 KiB) Downloaded 31 times
- Cap_1000uF_160V-Part_2.step
- (98.3 KiB) Downloaded 20 times
Thank you very much Roy_043 You got it.Roy_043 wrote: ↑Thu Feb 24, 2022 5:46 pm The problem seems related to the use of a PartDesign Body. If you replace it with a Part SimpleCopy the applied face colors are exported to the STEP file.
Re: [Solved] Exporting STEP loses color (2)
- adrianinsaval
Re: Issue #6451 - Exporting STEP loses color
Renamed. Thanks adrianinsaval
