Unable to position component in relation to used angles
kreyren
Post by kreyren »
The "Feet" (red) is designed to lay flat in relation to it's connection point:
The issue is that as soon as i change the "Leg Angle" (yellow) the object gets misplaced:
Q: How can i make the placement to be correctly parametrized after "Leg Angle" changed?
Klip_v2.FCStd
(120.13 KiB) Downloaded 15 times
openBrain
Re: Unable to position component in relation to used angles
Post by openBrain »
The easy way is to Part/Compound (or Part/Union, or set in a Part container) both leg and foot, then apply the rotation to the compound.
Other wise you'll get some mathematical computation needed. ;)
