BUG: "Part Design" > "Hole" > "Model Thread" > "Thread Depth" > "Dimension"
lual
Post by lual »
Hi, the new feature (Freecad 0.20) for threads in a hole has a small bug.
Description
"Part Design" >
"Hole" >
"Model Thread" >
"Thread Depth" >
"Dimension" >
pressing "OK" resets the given value to the value for the for hole-depth!
Please see the pictures...
I've reported this issue also at github here: https://github.com/FreeCAD/FreeCAD/pull ... -998214196
My FreeCAD version info
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.26683 (Git) AppImage
Branch: (HEAD detached at 0388fbc)
Hash: 0388fbc98d49d874fb341b9037a743bc691d501f
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Kind Regards
lual
bug_gewindebohrung.FCStd
(640.77 KiB) Downloaded 10 times
Re: BUG: "Part Design" > "Hole" > "Model Thread" > "Thread Depth" > "Dimension"
Hi and welcome to the forum!
I remember faintly that this has been discussed before, perhaps someone knows it? So I kindly ask you to respect our error reporting process, which starts with a discussion in the forum.
And please add your full FreeCAD infos, in a couple of weeks, nobody will know what exactly you meant by "0.20".
I can confirm the error. Can you please add a ticket to the bug tracker and link this discussion to it and vice versa?
As a workaround you can change the thred depth in the Data properties. However, this has to be redone every time you open and confirm the hole dialog.
lual
Post by lual »
chrisb wrote: Mon Dec 20, 2021 9:53 pm Can you please add a ticket to the bug tracker and link this discussion to it and vice versa?
... https://tracker.freecadweb.org/view.php?id=4808
thx
uwestoehr
Post by uwestoehr »
This PR fixes the issue your reported and also some other thread depth logic issues:
https://github.com/FreeCAD/FreeCAD/pull/5272
lual
Post by lual »
Wow - very quick fixed.
Thank you!
uwestoehr
Post by uwestoehr »
lual wrote: Tue Dec 21, 2021 8:52 am Wow - very quick fixed.
Let's see. I merged the bugfix now.
Please test it out with the next build we provide every Sunday evening:
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
(The build number must be greater than 26725.)
Please report an further issues you see regarding threaded holes.
lual
Post by lual »
uwestoehr wrote: Wed Dec 22, 2021 12:31 am Please test it out...
Tested with Rev 27008. Well done. Thanks
