Hello!
I am attempting to create 2 copies. each 120 degrees apart, of a feature on a part I am trying to make. Most CAD programs I have used in the past refer to this as a circular array or polar array, and, looking at the wiki, this also seems to be the case in FreeCAD. However, I am unable to actually find any of these functions in my version of FreeCAD (0.19). I have attempted to find these functions while in Part mode(?), Part Design mode, and sketcher mode. In part design mode, there is a "Create Polar Pattern Feature" function, but it appears that the shapes I'm using (extruded sketches) can't have this function performed on them.
The Wiki article about circular arrays describes a way to find the feature:
Select the Modification → Array tools → Draft CircularArray.svg Circular array option from the menu.
However, I don't see a "Modification" anywhere in my GUI.
Attached are images of my GUI to show that I'm not crazy (or to be damning evidence to the contrary), let me know if I'm missing helpful info. Any help would be greatly appreciated.
How to create circular arrays
- Back Case.FCStd
- (13.02 KiB) Downloaded 32 times
- Sketcher.png (80.52 KiB) Viewed 2124 times
- Part.png (95.75 KiB) Viewed 2124 times
- Part design.png (101.49 KiB) Viewed 2124 times
Re: How to create circular arrays
When using Part workbench use the polar array from Draft workbench.
Thank you for responding!TheMarkster wrote: ↑Tue Dec 07, 2021 2:43 am When using Part workbench use the polar array from Draft workbench.
I don't see a "Polar Array" option on the toolbar up top or under the "Part" dropdown. Could you direct me to where I might find this feature?
- Part dropdown menu.png (26.58 KiB) Viewed 2082 times
Draft WB|Modification|Array Tools|Polar Array
I also think there should be some convenience links in Part workbench for the array tools, the clone tool, and for creating a new sketch.
- thomas-neemann
- papyblaise
Merge the 2 Pads, in the Draft workshop, unroll the "Array" tab you will find the "Polar Array" tool
- Array.PNG (59.2 KiB) Viewed 1889 times
- Array.FCStd
- (23.06 KiB) Downloaded 25 times
With PartDesign wb.
- Capture.PNG (9.83 KiB) Viewed 1810 times
- Back Case_SHALM.FCStd
- (43.18 KiB) Downloaded 21 times
