Assembly 4 Stopped linking parts
After quite a bit of assembly work "Assembly 4" It won't any longer allow me to attach another part. I keep getting the message as shown in the screen shot. Have no idea how to correct this if it is possible.
Thanks in advance for any help.
Routerworks
Routerworks
Re: Assembly 4 Stopped linking parts
Version ?
Error message in text mode for further research ?
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Hash: 7b5e18a0759de778b74d3a5c17eba9cb815035ac
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Sorry I didn't understand your second question.
Thank you.
Thank you.
Does this help. It is a copy of the error message.
'NoneType' object has no attribute 'TypeId'Running the Python command 'Asm4_insertLink' failed:
File "C:\Users\Laurence Salamey\AppData\Roaming\FreeCAD\Mod\Assembly4\insertLinkCmd.py", line 87, in Activated
if parent.TypeId == 'App::Part' and parent.getParentGeoFeatureGroup() is None:
Here is the warning:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- Screenshot 001.PNG (245.7 KiB) Viewed 3677 times
in order to activate that part of the code, an existing link must be selected. In order to produce that error, that link must be outside of the assembly. Can you clear the selection (click somewhere in an empty space) and try again ?Routerworks wrote: ↑Sat Nov 27, 2021 5:38 pm File "C:\Users\Laurence Salamey\AppData\Roaming\FreeCAD\Mod\Assembly4\insertLinkCmd.py", line 87, in Activated
Anyway, that is a bug that should not happen, I'll correct it
in your screenshot, the "Insert Link" command is inactive, which is very strange: can you please show the root of the model tree (the top-most part) ?Routerworks wrote: ↑Fri Nov 26, 2021 5:32 pm After quite a bit of assembly work "Assembly 4" It won't any longer allow me to attach another part. I keep getting the message as shown in the screen shot.
I tried clicking in open space and it didn't help.
When I click on an assembly body the Link lights up however, if I then click on "Link" I get the error.
Clicking on a part below won't light up the Link icon.
Thanks a lot for your help.
- Screenshot 003.PNG (295.41 KiB) Viewed 3553 times
- Screenshot 002.PNG (302.06 KiB) Viewed 3553 times
- Screenshot 003.PNG (295.41 KiB) Viewed 3547 times
- Screenshot 002.PNG (302.06 KiB) Viewed 3547 times
