[sketcher] How do CloseShape and ConnectLines features work?
uwestoehr
Post by uwestoehr »
Today I wanted to try out this sketcher feature: https://wiki.freecadweb.org/Sketcher_CloseShape but can't get it to work.
Here is my use case:
Sketch-close-bug.FCStd
(6.37 KiB) Downloaded 20 times
When I select the endpoints of the polyline and use the feature, I get an over-constrained sketch but nothing changed visible.
The same is when I select a point of the polyline and the single line.
The same is when I select both points of the single line.
Using the same testfiles with the ConnectLines feature, https://wiki.freecadweb.org/Sketcher_ConnectLines I get no success.
Do I do something wrong and if yes, what is my mistake?
abdullah wrote: .
Version: 0.20.26457 (Git)
Hash: 563743e7e657321ae4e02eeeb9af83e378903e4e
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: [sketcher] How do CloseShape and ConnectLines features work?
As far as I understand the docs you should select unconnected elements.. That works here.
OS: macOS 10.16
Version: 0.20.26375 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
I have added to the wiki.
uwestoehr
Post by uwestoehr »
chrisb wrote: Mon Nov 22, 2021 10:14 pm As far as I understand the docs you should select unconnected elements.. That works here.
Do you have a screencast for me? Here is mine:
Roy_043
Post by Roy_043 »
You need to remove existing Coincident constraints and select edges not points. The selection order, and the direction of the edges determines the result.
uwestoehr wrote: Mon Nov 22, 2021 11:25 pm Do you have a screencast for me?
Do you still need the screencast after Roy's comment? Except for the upper left lines are your elements connected to other elements.
uwestoehr
Post by uwestoehr »
Roy_043 wrote: Tue Nov 23, 2021 8:33 am You need to remove existing Coincident constraints and select edges not points. The selection order, and the direction of the edges determines the result.
Shame on med :oops: I still don't get it to work:
- I just created a polyline and now I want to close it
- so I select now the two edges that should be connected, but this fails:
- as next try, I thought I can use the single line to close the polyline
- so i selected these 3 edges
But this is the result:
uwestoehr
Post by uwestoehr »
Next try:
- maybe one has to select the whole polyline to get it closed:
So I still don't get it closed.
A screencast would help me much.
However, since I fail embarrassingly I think the feature should either be improved somehow or better documented.
Roy_043
Post by Roy_043 »
There should not be any existing coincident constraints. So starting from a polyline does not make sense.
You should select all edges of the shape you want to create. And since the selection order is important you should select the edges one by one.
uwestoehr
Post by uwestoehr »
Roy_043 wrote: Tue Nov 23, 2021 7:32 pm There should not be any existing coincident constraints. So starting from a polyline does not make sense.
many thanks! So a polyline cannot be closed this way. I will add this info to the Wiki.
I now also get why the box selection fails. The lazy guy I am I use this selection method the most (to save clicks) therefore I did not come to the idea to select all segments with each a click.
However, now that I understand the feature, for me the main issue is that one does not know the direction of the lines in advance, so one often needs to undo and select in another order to get the desired result.
I assume there is no easy way to improve this.
