Face: invalid tolerance value
56jimalexander
Re: Face: invalid tolerance value
Post by 56jimalexander »
I don't see OPenSCad as an addon. Where do I find this "binary"?
edwilliams16
Post by edwilliams16 »
https://openscad.org/downloads.html It's an external program called by FreeCAD>
56jimalexander
Thanks ED. Where to install it so that it's available as a workbench?
edwilliams16
Install it wherever you normally install programs. The path to the executable is in Preferences|OpenSCAD
Screen Shot 2021-11-21 at 7.45.34 AM.png (24.43 KiB) Viewed 1033 times
keithsloan52
Post by keithsloan52 »
56jimalexander wrote: Sat Nov 20, 2021 6:54 pm Thanks ED. Where to install it so that it's available as a workbench?
The OpenSCAD workbench is a standard FreeCAD workbench, has been since FreeCAD 0.13, it is not an addon workbench.
Just select it like Part, Part Design etc
Image 24-11-2021 at 21.38.jpeg (19.85 KiB) Viewed 946 times
You do have to go to select it as a workbench
Then go to FreeCAD Preferences should display
Image 24-11-2021 at 21.41.jpeg (110.48 KiB) Viewed 946 times
Then selected the OpenSCAD icon should display
Image 24-11-2021 at 21.47.jpeg (87.72 KiB) Viewed 946 times
First option is where the location of the OpenSCAD executable should be set if it has not defaulted to the correct location.
56jimalexander
OK then! Thank you for clarifying all of this.
