Part.Loft - Wrong Vertices Linked?
- wandererfan
In a Part.Loft, is there a way to control which vertex on profile p gets linked to which vertex on profile p+1?
In SimpleLoft, v1p1 links to v2p2, v3p1 links to v4p2, etc, so the Loft is not very useful. In SnakeLoft, v1p1 links to v1p2, v2p1 links to v2p2, etc and the Loft is sensible.
Is there something in how the profiles are created that controls this? Something in the angle/cuvature of the loft lines?
AAA,
wf OS: Ubuntu 12.04.4 LTS
Platform: 64-bit
Version: 0.14.3379 (Git)
Hash: 2d724365cfb82048e7ebf3346fabfe904549e598
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
AAA,
Platform: 64-bit
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
- SnakeLoft.fcstd
- Loft with sensible vertex choices
- (6.73 KiB) Downloaded 87 times
- SimpleLoft.fcstd
- Loft with rubbish vertex choices
- (9.04 KiB) Downloaded 73 times
Re: Part.Loft - Wrong Vertices Linked?
What I have found is anything past half way/45* will cause it to flip. This shows up when rotating the sketches in a straight line as well. You can see this by drawing 2 square sketches at some distance apart, say 50, and loft between them. rotate one sketch 44* and note the direction of the twist. Now change the rotation to 46* and you will see the direction of the twist flip.
What is needed is a way to pick which points loft where, kind of like an alignment type tool. This came up before in the process of lofting a twisted star pattern ring if I'm remembering correctly. If I find the thread, I'll post back.
Mark
EDIT - Found it, it was in the "how can i draw something like this?" thread.
Mark
This post made with 0.0% Micro$oft products - GOT LINUX?
Hi WF
I get the problem with this version of 0.14dev but not with 0.13
Platform: 64-bit
Version: 0.14.3386 (Git)
Hash: f2a922bdf2125a94a6f7a8ec96474f5183097cff
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
If I force a recompute by toggling Ruled parameter, 0.14dev above gives the error icon in treeview when in ruled true. However 0.13 below works in both modes.
Platform: 64-bit
Version: 0.13.1830 (Git)
Branch: releases/FreeCAD-0-13
Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
It might be an OCC issue because it works properly after a recompute in this version as well.
Platform: 64-bit
Version: 0.14.3236 (Git)
Hash: 629d5cc1fe193c88d1dfefccd000bfc7cd6f9fc0
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
I am going to recompile that last version to test if it is OCC or the last few commits of FreeCAD 0.14dev that vary between the two.
I'll post back with the result in a few minutes...but I am betting this is an OCC bug.
Jim
Platform: 64-bit
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
Platform: 64-bit
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
Platform: 64-bit
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
Jim
OK, guys I can confirm that this seems to be OCC version related....either there is a bug or there has been some change or other that we need to account for.
Platform: 64-bit
Version: 0.14.3389 (Git)
Hash: a1e049bc8a687c52d82baa6e96d2f31d2a3f5862
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
This latest FreeCAD compiled against the old OCC 6.5.0 from default Ubuntu 12.04, works perfectly after a recompute is forced.
Jim
Platform: 64-bit
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
Jim
- wandererfan
I think the error icon is the equivalent of this in the Gui: but I don't know what would be the objection to having both boxes ticked.jmaustpc wrote:If I force a recompute by toggling Ruled parameter, 0.14dev above gives the error icon in treeview when in ruled true. However 0.13 below works in both modes
Agreed, but there is nothing obvious in the calls to OCC (BRepOffsetAPI_ThruSections) that would govern this. I'll keep digging. There are also other OCC calls that can be used to make a loft-like object. I'll look into that too. Maybe we'll need 2 functions (linear/curved lofts??) or an extra parameter.quick61 wrote:What is needed is a way to pick which points loft where, kind of like an alignment type tool. This came up before in the process of lofting a twisted star pattern ring if I'm remembering correctly. If I find the thread, I'll post back.
wf
- wandererfan
We make progress slowly. BetterLoft.png uses the same profiles and options as RubbishLoft.png above.
WF
Platform: 64-bit
Branch: CircleLoft
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
More to come.WF
Platform: 64-bit
Branch: CircleLoft
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
Yes i would say Loft tool would need to get possibility to control the flow and "auto open/close" similar as Ruled Surface tool did:
viewtopic.php?f=3&t=6127&p=49224#p48969
ATM if you are in luck you will get wanted result. If not you have to find a workaround.
Hi WF
What it is, is a toggle between the type of surface to be produced either being Ruled or not, regardless of the Loft's producing a solid or a surface. For anyone who does not know, a Ruled Surface is a geometric principle, it is a surface that can be described but straight lines, if you don't know what I am talking about, have a look on wikipedia, it has a great article, search "ruled surface".
So Loft can produce a solid whose sub-component surface is either a ruled or not ruled, surface. Loft can also produce a surface only, that is not a solid, but that surface can still be either a ruled surface or not ruled surface.
My testing of the latest FreeCAD 0.14dev code both compiled against occ6.5.0 and the same FreeCAD code compiled against OCC6.7.0 (OCE0.16) shows that the "twisted issue" you found in Loft only happens with the later OCC.
Jim
I know the answer to that because I thought the same thing and ask Werner about it when he first made the tool.wandererfan wrote:but I don't know what would be the objection to having both boxes ticked.
Jim
The reason for the failure has to do with the placement applied on the sketches because I assume the internal orientation of the shapes doesn't fit to what the loft needs. All three sketches have totally different rotation axes and this might be the major problem.In a Part.Loft, is there a way to control which vertex on profile p gets linked to which vertex on profile p+1?
As a quick test I copied the sketches into a new document and reset the placements. Then for sketch two I set rotation axis=(0,1,0) angle=90 deg and for sketch three the same axis and angle=180 deg. So, this gives the same form (but in a different position of course) and the the loft works as expected.
I see it comes down to sketch rotation/placement? I assumed something like that when trying out different thing in this thread:
But could not pin point "solution". Could this be solved only by rotating sketch around one of the axis or does the sketch itself needs to be moved (location) too?
