Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
vk7krj
Re: Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
Post by vk7krj »
I have a problem loading an scad file into freecad and this appears to be the correct place to ask about it.
It appears freecad is not using the difference command and the object is shown as just a series of solid cubes and disks when it should be a spoked flywheel. I have tried to put a couple of jpg's in to show, but can't figure out how to put them in this message so I have pasted the openscad file in at the bottom..
My freecad info is-
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
and openscad is-
OpenSCAD version 2021.01
The openscad file:-
$fn = 128;
//Set up the dimensions
hubdiameter = 25;
shaftdiameter = 12;
wheeldiameter = 100;
hubthickness = 10;
rimthickness = 20;
spokethickness = 8;
numberofspokes = 5;
//Set draught so mold can be
//removed from sand
draught = 2;
//Don't change the next 3 lines
wheelrimthickness = (wheeldiameter - rimthickness);
spokelength = (wheeldiameter-hubdiameter+5);
rotation = 360/(numberofspokes);
//Set the ovalness of the spokes (1=round,
//  less than one is oval in one plane,
//  more than one is oval in the other plane
ovality = 1.5;
// Make half a wheel for casting
difference(){
//Wheel rim
difference(){
  difference(){
    color ("violet")
    cylinder(h=12,d1=wheeldiameter,d2=wheeldiameter-draught,center=true);
//Two 3mm holes so the wheel halves
//can be correctly registered in the mold
    translate([0, wheeldiameter/2-5, -5])
    cylinder(h=10,d=3);
    translate([0, -(wheeldiameter/2-5), -5])
    cylinder(h=10,d=3);
//Cut out the annulus and make the spokes
difference(){
    color ("blue")
    cylinder(h=13,d1=wheelrimthickness-draught,d2=wheelrimthickness,center=true);
   for (i=[1:numberofspokes]){
    rotate([90,0,rotation * i])
    scale([ovality,1,1])
    color ("red")
//comment out cylinder line and uncomment
//cube line for rectangular spokes
    cylinder(h=spokelength, d=spokethickness, center=false);}
//    cube([65,spokethickness,5],center=true);}
  color ("lightblue");
cylinder(h=12,d=15,center=true);
//This cube differences out half the wheel
//to make a mold for casting
translate ([0, 0, -10])
cube ([wheeldiameter+10, wheeldiameter+10, 20],center = true);
//Draw half a hub center
difference(){
  color ("green")
  translate ([0, 0, 2.5])
  cylinder(h=5,d1=hubdiameter,d2=hubdiameter-draught,center=true);
  color ("navy")
  cylinder(h=11,d1=shaftdiameter,d2=shaftdiameter-draught, center=true);
Hi and welcome to the forum!
Please retry with a current 0.20 version.
Please edit your post and put the code in code tags using the button </>. That makes the post easier to read.
vk7krj
Post by vk7krj »
Thanks Chrisb, I have now installed the current 0.20 version, it made it a little better but still not correct. If I open the stl of the flywheel, that displays correctly but the scad file is still not differencing properly. I have put in jpegs of the two files as shown in freecad- the first one is the scad file, the second is the stl created from it in openscad.
flywheel scad.JPG (39.06 KiB) Viewed 2616 times
flywheel stl.JPG (29.84 KiB) Viewed 2616 times
x-posting another issue that was opened before posting to the thread: issue #6810
When opening a OpenSCAD file I get the following error: (see files attached + error below)
Instead of opening the part with all subsections, it just makes a single cube.
16:27:03  Traceback (most recent call last):
  File "C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\importCSG.py", line 119, in open
    processcsg(tmpfile)
  File "C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\importCSG.py", line 177, in processcsg
    result = parser.parse(f.read())
  File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\ply\yacc.py", line 333, in parse
    return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
  File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\ply\yacc.py", line 1120, in parseopt_notrack
    p.callable(pslice)
  File "C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\importCSG.py", line 854, in p_multmatrix_action
    parentcolor=p[6][0].ViewObject.ShapeColor
<class 'IndexError'>: list index out of range
Tested on
OS: macOS 10.16
Version: 0.19.24366 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
I also tried versions 0.20 dev, 0.19.4, and 0.19.1 on Windows 10.
thorlabs_optomech.scad
(161.51 KiB) Downloaded 23 times
baseplate_test1.scad
(1.01 KiB) Downloaded 25 times
chennes
Post by chennes »
I was not able to reproduce the problem reported in the ticket -- FreeCAD loaded the file fine for me using
Version: 0.20.28764 (Git)
Build type: Debug
Hash: 4f9eb9ebcea67bff2a46cfc97ae125472f115a11
Python 3.8.6+, Qt 5.15.2, Coin 4.0.1, OCC 7.5.3
Chris Hennes
Pioneer Library System
chennes wrote: Fri Apr 29, 2022 1:51 pm I was not able to reproduce the problem reported in the ticket -- FreeCAD loaded the file fine for me using
@chennes which ticket?
chennes
Post by chennes »
#6810
Chris Hennes
unphased
Cannot open openscad model
Post by unphased »
Here is the error I'm getting.
WARNING: Token 'DOT' defined, but not used
WARNING: Token 'WORD' defined, but not used
WARNING: There are 2 unused tokens
WARNING: Couldn't create 'parsetab'. [Errno 13] Permission denied: '/usr/share/freecad/Mod/OpenSCAD/parsetab.py'
  File "/usr/share/freecad/Mod/OpenSCAD/importCSG.py", line 84, in open
    processcsg(tmpfile)
  File "/usr/share/freecad/Mod/OpenSCAD/importCSG.py", line 142, in processcsg
  File "/usr/lib/python3/dist-packages/ply/yacc.py", line 333, in parse
  File "/usr/lib/python3/dist-packages/ply/yacc.py", line 1120, in parseopt_notrack
    p.callable(pslice)
  File "/usr/share/freecad/Mod/OpenSCAD/importCSG.py", line 391, in p_offset_action
    if subobj[0].Shape.Volume == 0 :
<class 'RuntimeError'>: shape is invalid
How can I find out more about what modifications I should try to make to the scad definition to prevent this problem, or could I do some hack to remove the check?
Re: Cannot open openscad model
Please add the file/code to the original post please, along with your full About info
Edit: @unphased I've merged your thread in to the pre-existing 'Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks' thread
chennes
Post by chennes »
unphased wrote: Tue May 17, 2022 5:50 am
We fixed this warning a couple of weeks ago -- make sure you're running the latest available dev build, or wait for the release of 0.20 in the coming weeks. Then let's see if the problem persists.
Chris Hennes
