Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
Re: Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
@malorezzanzo00492 can you provide a test file and also your full About info? TIA
Think offset only works on 2d shapes hence the test for Volume == 0 and barf, what 2d shapes are you performing a union on?malorezzanzo00492 wrote: ↑Sat Aug 13, 2022 9:48 pm There's a problem with linear_extrude()offset()union(){} and with linear_extrude()offset()union(){}.
In the second case FreeCAD gives this error:In the first case, instead, it seems to ignore the union() instruction.File "...", line ..., in p_offset_action
if subobj.Shape.Volume == 0 :
<class 'RuntimeError'>: shape is invalid
i.e Please supply a test file that gives a valid result with native OpenSCAD - Thanks
@keithsloan52 @Kunda1
This is an example of code falling into the second case:
In the attachment "unionOpenscad.png" the correct result with openscad, while in the attachment "unionFreecad.png" the wrong result with freecad.
This is an example of code falling into the first case:
In the attachment "differenceOpenscad.png" the result with openscad, while in freecad it gives the aforementioned error.
My About info:
linear_extrude(200)offset(delta=-10)
union(){
square(100);
translate([100,0,0])square(100);
difference(){
square(100);
translate([50,0,0])square(100);
My About info:
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Italian/Italy (it_IT)
- differenceOpencad.png (2.54 KiB) Viewed 1255 times
- unionFreecad.png (3.14 KiB) Viewed 1255 times
- unionOpenscad.png (4.64 KiB) Viewed 1255 times
Last edited by malorezzanzo00492 on Wed Aug 17, 2022 7:14 pm, edited 1 time in total.
Another problem, maybe correlated is this code with this particular polygon:
It gives this error:
Based on the polygon points, sometimes gives error and sometimes works.
My About info:
linear_extrude(10)offset(delta=-2)polygon([[0,0],[0,230],[33,230],[33,260],[0,260],[0,500],[500,500],[300,-3],[243,-2],[243,-27],[125,-26],[123,-1]]);
<Exception> makeOffset2D: result of offsetting is null!
Recompute failed! Please check report view.
My About info:
Other 2 problems:
The following code should render the "arcOpenscad" attachment, while it renders the "arcFreecad" one. The problems should be somewhere in the rotate.
This other piece of code should be a door frame as in the "doorOpenscad" attach, without the circular object at its feet:
My about info:
arcElevation = 185;
arcRadius = 52;
arcWid = 10;
arcLen = 150;
rotate([0,90,0]){
// first arc
translate([0,0,-arcWid])union(){
linear_extrude(arcWid)square([arcLen,arcElevation]);
translate([arcLen/2,arcElevation,0])cylinder(h=arcWid,r=arcLen/2);
// second arc
translate([0,0,-100])union(){
translate([(arcLen)/2,arcElevation,0])cylinder(h=arcWid,r=(arcLen)/2);
// central part
cube([arcLen,100,arcElevation]);
//include <BOSL2/std.scad>
module doorframe (arcElevation,arcHeight,span,frameWidth,frameLength=2,subframeLength=7,height=210){
arcWidth = frameWidth-2;
arcRadiusInt = (span-6)/2;
arcRadiusExt = (span+3)/2;
arcScale = [1,(height-arcElevation)/(span/2),1];
arcPos = [0,arcElevation,-arcWidth/2];
framePos = [-(span+frameLength*2)/2,0,-frameWidth/2];
subframeWidth = frameWidth + 2;
subframePos = [-(span+frameLength*2+subframeLength*2)/2,0,-subframeWidth/2];
arcSorroundingPos = [0,arcElevation,-0.5];
rotate([90,0,0])union(){
//frame
translate(framePos)
difference(){
cube([span+frameLength*2,height+frameLength,frameWidth]);
translate([frameLength,0,0])cube([span,height,frameWidth]);
//subframe
translate(subframePos)
difference(){
cube([span+frameLength*2+subframeLength*2,height+frameLength+subframeLength,subframeWidth]);
translate([subframeLength,0,0])cube([span+frameLength*2,height+frameLength,subframeWidth]);
//arc
translate(arcPos){
scale(arcScale)
difference(){
// pie_slice(ang=180, l=arcWidth, r=arcRadiusExt);
cylinder(h=arcWidth, r=arcRadiusExt);
cylinder(h=arcWidth, r=arcRadiusInt);
translate([-arcRadiusExt,-arcRadiusExt,0])cube([arcRadiusExt*2,arcRadiusExt,arcWidth]);
//between arc and frame
translate(arcSorroundingPos)
difference(){
translate([-span/2,0,0])
cube([span,height-arcElevation,1]);
scale(arcScale)
cylinder(h=1,r=arcRadiusInt);
doorframe(arcElevation=174,arcHeight=36,span=71,frameWidth=12);
- doorFreecad.png (4.75 KiB) Viewed 1217 times
- doorOpenscad.png (3.3 KiB) Viewed 1217 times
- arcFreescad.png (7.55 KiB) Viewed 1217 times
- arcOpenscad.png (3.79 KiB) Viewed 1217 times
Thanks for reporting
@chennes I have created the following test files from details in the this thread
I have added a fix to offset action to do a checkObjShape to check and perform recompute of the object if requiredkeithsloan52 wrote: ↑Wed Aug 17, 2022 9:36 pm Thanks for reporting
Union_Squares.scad
Difference_Squares.scad
Offset_polygon.scad
Door_Arc.scad
ArcOpen.scad
to https://github.com/KeithSloan/OpenSCAD_Alt_Import this for me fixes difference.scad
def p_offset_action(p):
'offset_action : offset LPAREN keywordargument_list RPAREN OBRACE block_list EBRACE'
# print('Offset Action')
# print(len(p))
# print(f'p6 : {p[6]}')
if len(p[6]) == 0:
newobj = placeholder('group',[],'{}')
elif (len(p[6]) == 1 ): #single object
subobj = p[6][0]
else:
subobj = fuse(p[6],"Offset Union")
if 'r' in p[3] :
offset = float(p[3]['r'])
if 'delta' in p[3] :
offset = float(p[3]['delta'])
#print(subobj.Shape)
#print(dir(subobj.Shape))
#print(subobj.Shape.ShapeType)
checkObjShape(subobj)
With Offset_polygon the supplied offset is a negative number which causes errors
23:25:33 <Exception> makeOffset2D: result of offsetting is null!
23:25:33 Recompute failed! Please check report view.
23:25:33 Recompute failed : Offset2D
23:25:33 End processing CSG file
@Kunda1
Still to debug problems with DoorArc and Union_Squares
Maybe open a new forum thread to discuss it?Should FreeCAD makeOffset2D be able to handle negative offsets? @Kunda1
(This has been reported in Debian: https://bugs.debian.org/cgi-bin/bugrepo ... bug=860789)
Quoting the Debian Bug:
(Attaching a screenshot comparing FreeCAD 0.20.1 with OpenSCAD 2021.01, both Debian packaged versions.)in attempting to convert from OpenSCAD to STEP,
found the advice here and followed it:
https://forum.lulzbot.com/viewtopic.php?t=243
however the following file has all of its "difference" (removal)
objects turned into "unions" (additions):
http://hands.com/~lkcl/microdesktop_prog2.scad
- Screenshot from 2022-09-11 13-32-14.png (145.81 KiB) Viewed 935 times
That file contains an empty "union()" that appears to confuse FreeCAD -- we've got code to handle that condition, but it must not be working right. I'll try to take a closer look.
