Help creating a mold from an existing model
TuttleJA
Post by TuttleJA »
HI, First time user. I have a completed part and I would like to use it to create a mold. Can that be easily done in FreeCAD? If so, how?
mat-n-logo-3.stl
(355.65 KiB) Downloaded 29 times
Re: Help creating a mold from an existing model
Hi and welcome to the forum!
It can well be done and there are hundreds of topics in the forum about converting an STL into a solid. Maybe even thousands.
TuttleJA
Post by TuttleJA »
Thank you for replying. Isn't this already a solid? (I would have uploaded the FreeCAD file, but they said the file was too big.) So, here's a screenshot.
TuttleJA
Post by TuttleJA »
This shows some of the detail better..... The 'S' and the lettering are raised.
The mesh is not a solid, it's onla a, well, mesh made of points and lines. This can be interpreted as a solid, but it isn't one.
TuttleJA
Post by TuttleJA »
Thank you, I'll look into that....
papyblaise
Post by papyblaise »
if you have the complete Fc file, you place a part on top and you do a boolean subtraction
TuttleJA
Post by TuttleJA »
Yes, I have a Fc file of the part. What you said sounds like very useful information. I'll try it (as soon as I learn how it's done). Thank you.
domad
Post by domad »
TuttleJA wrote: Mon Aug 30, 2021 3:12 pm .....
Hi TuttleJA
This is the result of solidification
TuttleJA
Post by TuttleJA »
Hi domad, That's very nice... Maybe some day I'll learn how to add color... Right now, what I need is a negative mirror image so I can 3-d print a mold of the part. Then I plan to use the mold to make rubber parts that look identical to the part you made solid and colorful. Using Boolean, I think I was able to made the part solid and then get the negative/mirror effect, but it's on the wrong side of the mat.
