Making Surface array , how to make point array ?
bleber
Post by bleber »
Hi.
I have a curved surface, I make a point cloud with points workbench, and I like to make a point array with witha a sphere, I use draft workbench point array , but I have awarming message from console.
Wrong input: point object doesn't have 'Geometry', 'Links', or 'Components'
I attache my file in the bottom.
Thanks.
moeb.FCStd
(59.13 KiB) Downloaded 30 times
TheMarkster
Re: Making Surface array , how to make point array ?
Post by TheMarkster »
It looks like Draft point array doesn't currently work with the Points object. Here is a macro I threw together to convert the Points object into a compound of Draft.points, which will work with the Draft point array. Select the Points object and run the macro. It will take a while depending on how many points you have. Look at the status bar to see a progress indicator.
Snip macro screenshot-0df58e.png (145.85 KiB) Viewed 945 times
points.FCMacro
(714 Bytes) Downloaded 37 times
hammax
Post by hammax »
... just for fun I also tried to position spheres on a moebius tape via PathArray.
Moebius.FCStd
FC.18.4
(228.85 KiB) Downloaded 21 times
Moebius_4.FCStd
FC.18.4
(80.35 KiB) Downloaded 24 times
Palmtree
Post by Palmtree »
bleber wrote: Thu Aug 12, 2021 11:04 pm I have awarming message from console.
It has been fixed/solved refer to @Roy_043 ==> https://forum.freecadweb.org/viewtopic.php?f=23&t=71957
I have reattached your model free of error (thanks to @Roy_043's patches). Please mark the post as [Solved]
Cheers
Version: 0.21.30430 (Git)
Hash: 9e1ed4a68ad43309c2b38f7f5efbb1feac4323cb
  * Behave-Dark-Colors 0.1.1
  * BIM 2021.12.0
  * Design456 0.0.1
  * dodo
  * Dracula 0.0.2
  * fasteners 0.4.10
  * Help 1.0.3
  * Parts_library
  * PieMenu
  * Reinforcement
  * SketchArch
moeb-R2.FCStd
(64.05 KiB) Downloaded 17 times
Image 1.jpg (318.03 KiB) Viewed 651 times
Vincent B
Post by Vincent B »
TheMarkster wrote: Fri Aug 13, 2021 12:54 am Here is a macro I threw together to convert the Points object into a compound of Draft.points, which will work with the Draft point array.
Great! a such macro is missing in Point Wb. Should be added to.
Vincent B
Post by Vincent B »
Here a tutorial to build surface from point cloud:
https://forum.freecadweb.org/viewtopic.php?f=36&t=63949
Vincent B
Post by Vincent B »
using Gordon surface.
moeb_vb.FCStd
(569.22 KiB) Downloaded 16 times
