Crash on sketch item delete
quick61
Re: Crash on sketch item delete
Post by quick61 »
Well, it looks like wmayer stopped the crashing but now their seems to be a side affect to the fix. :(
Now whenever a line is selected and deleted, it is still visible until you click the view refresh button.
I am now going back and rebuilding with a clean compile just to be sure, but at the moment, this does not look right.
Rebuilding, so no FreeCAD about info available at the moment. ;)
Mark
This post made with 0.0% Micro$oft products - GOT LINUX?
quick61 wrote:Well, it looks like wmayer stopped the crashing but now their seems to be a side affect to the fix. :(
Mark
My fix is not responsible for this side effect.
The crash happened because due to the deletion of the pad the selection becomes empty and this wasn't handled in the view provider of the sketch. I simply added a check to return immediately if there is nothing in the selection list.
So, this means the side effect was already there and I could confirm it with the 0.13 version. But I couldn't find out what changes on the sketch to make this effect appearing.
quick61
Post by quick61 »
Mark
Well, at least it isn't something new. :) The good news is the crashing has stopped and closing the sketch and opening the edit again seems to make this behavior go away. So for the moment, there is that for a work around, but now, if the Pad is not manually deselected, it is deleted. Sorry to say, it looks like more work.
Should I make out another Mantis ticket on this new problem?
Mark
OS: Ubuntu 13.10
Platform: 64-bit
Version: 0.14.3342 (Git)
Hash: ca6d37202593752c0eeeb1ce56cb4d8c3baf27c0
Python version: 2.7.5+
Qt version: 4.8.4
SoQt version: 1.5.0
OCC version: 6.7.0
Sure, go ahead!
quick61
Post by quick61 »
wmayer wrote:Sure, go ahead!
Done - issue #1483
Hope it's clear and throw enough. I left the "relates to" stuff up to you guys sense you all have a much better handle on that aspect than I.
Mark
triplus
Post by triplus »
I am quite sure i was experiencing this bug in the past and i am glad to see it is fixed!
