Start a sketch makes view upside down
run_the_race
Post by run_the_race »
I thought it was a bit unusual that if I make a sketch of the rear of an object, the sketcher makes the view upside down. Is there anyway to disable this? I went through the display preferences and could not find something.
Maybe it is useful and I just don't understand how it is superior than always having up as up.
Bance
Re: Start a sketch makes view upside down
Post by Bance »
Woefully short of information, to even comment.
edwilliams16
Post by edwilliams16 »
Guessing you have your sketch attached to something - the Map Reverse parameter in the Data panel will do what you want.
Whatever direction upside down applies to: you may turn the attachment offset by 180° around z.
edwilliams16
chrisb wrote: Fri Apr 30, 2021 8:24 pm Whatever direction upside down applies to: you may turn the attachment offset by 180° around z.
I think you meant to say rotate by 180 about the x- or y-axis. The local z-axis of a sketch is normal to it, so rotating around z just spins the sketch around.
edwilliams16 wrote: Fri Apr 30, 2021 8:52 pm I think you meant to say rotate by 180 about the x- or y-axis. The local z-axis of a sketch is normal to it, so rotating around z just spins the sketch around.
Exactly. Around which axis to rotate depends on what exactly upside down means.
Bance
Post by Bance »
Buuuuuuut what if its downside uuuup? :lol: :lol:
Cadder
Post by Cadder »
Rotating each time you open sketch is not just annoying, but also place all shown dimension upside down (or downside up).
Is such reversion done by design?
thomas-neemann
Post by thomas-neemann »
Cadder wrote: Sat Sep 24, 2022 5:38 pm ...
is this a solution for you?
https://www.youtube.com/watch?v=GzWEVJ0Rp18
phpBB [video]
Version: 2022.709.28846 (Git) AppImage
Branch: LinkStage3
Hash: c880c050c5f7601e4bae6740de71500edf2be0c7
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Cadder
Post by Cadder »
thomas-neemann wrote: Sat Sep 24, 2022 6:24 pm is this a solution for you?
Looks great!
How did you achieve this? :o
