Ticket #6200 - version .19 release crash on surface creation
I don't want to submit a bug until I have someone confirm that this issue isn't something wrong with my environment.
The screen shot shows what is there before I click OK. Note the error message in report view. I've had this message before in pre release versions but never understood what it meant.
Clicking OK begins the crash and I'm prompted to close.
When I create this surface using a version from 2/21 there is no problem.
This is not an isolated instance with the release version. I've had to revert to a pre release.
Other than that I really like the release version.
OS: Windows 10 Version 2004
Version: 0.19.24275 (Git)
Branch: releases/FreeCAD-0-19
Hash: f4574cf02d08fedd0a416d798b7dfef0ca2b5579
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- illegal storage.jpg (278.65 KiB) Viewed 2049 times
- Screwdriverpost1.FCStd
- (214.82 KiB) Downloaded 56 times
Reason: Added GH ticket number to thread title
Re: version .19 release crash on surface creation
What am I supposed to do make it crash? You appear to be showing Surface004, which works for me. It also seems to almost duplicate Surface (one more edge to close it)
OS: macOS High Sierra (10.13)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438
Python version: 3.8.8
Qt version: 5.12.9
Locale: C/Default (C)
Qt version: 5.12.9
It might be a windows PC thing.
This is what I just did:
Launch the released version of version .19 and open the file I attached
Show surface04
Double click surface04 in tree to enter edit. Click OK
Hmmmmm....It worked.
Delete surface04.
Recreate surface using 2,3, or 4 surface tool. Select left edge. Select right edge. Select top edge.
For me, at this point, the surface does not attach to the top edge.
Select OK
Crash.
Show surface04
Delete surface04.
Select OK
Crash.
I confirm. That's carry out to an "acces violation" error.
Create a bug report and crossrefence between the ticket and this topic.
Please follow the instructions on tracker. Make sure to backlink the ticket to this thread.56jimalexander wrote: ↑Thu Apr 08, 2021 10:52 pm Thanks for confirming this. I don't know what your reply means. Should I submit a bug report?
I'm at the login for mantis bug tracker. Is this the right place? When I use my Freecad login I get "Your account may be disabled or blocked or the username/password you entered is incorrect."
You need to create a new account (it's not connected to the forum account, unfortunately)
It is sensible though, if you use the same user name, so that the relationship between both systems is clear.
