[bug #0004486] Techdraw: Error: detail area contains no geometry
DeepSOIC
Post by DeepSOIC »
Hi!
I have little idea how to use techdraw. Can anybody help?
I'm trying to insert a detail view, but nothing gets through, even though it seems like it should. And i get a warning:
DVD::execute - Detail - detail area contains no geometry
Here's the file:
baffle mk1 v02 drawing.FCStd
uses Lattice2 and Part-o-magic addons
(83.1 KiB) Downloaded 43 times
And info:
Version: 0.19.22474 (Git)
Hash: a44f8ffd427fa9b23b1f00dbf62d66cd152cd774
Python version: 3.8.5
Qt version: 5.12.6
DeepSOIC
Re: Techdraw: Error: detail area contains no geometry
Post by DeepSOIC »
After trying this on a cube and re-trying it on my project, i'm convinced it's a bug, as it does work with a cube of the same scale (1x1x1 m).
kisolre
Post by kisolre »
Confirmed with:
OS: Windows 8.1 (6.3)
Version: 0.19.22932 (Git)
Hash: 48365ecdbbde880ca4d1674cc0d8bae81d274d14
Python version: 3.6.8
Qt version: 5.12.1
Locale: Bulgarian/Bulgaria (bg_BG)
Forthman
Post by Forthman »
Why do you use a Simple Copy of a ShapeBinder ? :shock: :?:
If i use directly Module001 in source projection, it's fine ;)
Capture d’écran_2020-11-06_13-13-08.png (66.86 KiB) Viewed 1720 times
In View001
I just set Source projection to : Module001
and Direction to : X0.00 Y-1.00 Z0.00
@Forthman About info pls
Forthman
Post by Forthman »
OS: Linux Mint 19.3 (XFCE/xfce)
Version: 0.19.
Branch: unknown
Hash: b75cd3dd522c7c2589016160f5bb342ea6a7ed94
Python version: 3.6.9
Qt version: 5.9.5
Locale: French/France (fr_FR)
sory i don't remember how get the revision number :? (I made an update this morning)
edit : the modified file :
(75.73 KiB) Downloaded 33 times
DeepSOIC
Post by DeepSOIC »
Forthman wrote: Fri Nov 06, 2020 12:15 pm Why do you use a Simple Copy of a ShapeBinder ? :shock: :?:
It isn't a simple copy, and not of a shapebinder. It is a face that i extracted to make a dwg file to send it for CNC-ing (using Lattice2's Sublink feature).
Thank you for showing me that it works with the solid, now i can complete the drawing. It seems like the detail view does not work for faces... i'll check the theory later.
Forthman
Post by Forthman »
DeepSOIC wrote: Fri Nov 06, 2020 4:49 pm It is a face that i extracted to make a dwg file to send it for CNC-ing (using Lattice2's Sublink feature).
Ok, i don't use this workbench , understand better now ;)
DeepSOIC
Re: [bug] Techdraw: Error: detail area contains no geometry [has workaround]
Post by DeepSOIC »
investigated it a bit. Seems like detail view doesn't work for any object that is not a solid. I have tried a sketch, and a part-extruded sketch with "solid" unchecked. Merely changing "Solid" property of the extrusion makes the detail view work and not work.
DeepSOIC
Post by DeepSOIC »
