Where have all the workbench addons gone????
kisolre
Re: Where have all the workbench addons gone????
Post by kisolre »
Vagulus wrote: Sun Dec 06, 2020 2:21 am Where did I say that?
Vagulus wrote: Sun Dec 06, 2020 12:00 am I cannot find a downloadable binary build of FC any more recent than my current version (FreeCAD_0.19.22209_x64_LP_12.1.6_PY3QT5-WinVS2015.7z).
kisolre
Post by kisolre »
Conda builds included(not sure if still does) Assembly3 as a means to introduce and test it before it is officially included. Rather that I am not sure if there is any notable difference from user perspective.
Vagulus
Post by Vagulus »
Thanks very much for your patience.
I hope you (or one of the administrators) have pinned the relevant download link onto the Forum. It'll be a big help to newbies.
"It is much harder to simplify than to complicate."
Joseph Kimble
metropt
Post by metropt »
melwynfranciscarlo
Post by melwynfranciscarlo »
Hi!
I had stumbled upon the same problem the day before yesterday. Only the 3D Printing Tools Workbench shows up. I don't know why that happens; perhaps that's some Version issue, I do not know. I have Version 0.18.4 at the moment.
Regardless, that should NOT hold you back. Another route to get those workbenches is to manually install them using your Linux/Ubuntu Termimal window. It's simple. The steps are usually as follows:
1. Go to the External Workbenches webpage : https://wiki.freecadweb.org/External_workbenches
Screenshot from 2021-02-05 16-11-08.png (203.37 KiB) Viewed 15274 times
2. Find the Name of the Workbench you need, and then Click on the Code Link (the last column). It should take you a GitHub Page by now.
Screenshot from 2021-02-05 16-11-29.png (194.6 KiB) Viewed 15274 times
3. Copy the webpage URL on the GitHub site.
Screenshot from 2021-02-05 16-11-50.png (156.74 KiB) Viewed 15274 times
4. Open a Command Terminal (in Ubuntu, the shortcut is Control+Alt+T).
5. Type the following:
cd .FreeCAD/Mod
If an error, shows up, you can create the folder manually, like this (then repeat Step 5):
mkdir .FreeCAD/Mod
6. Then type the following:
git clone URL
NOTE : Replace the term 'URL' with the URL copied in Step 3 by pasting it into the terminal.
EXAMPLE :
git clone https://github.com/tomate44/CurvesWB
If the 'git' command does not work, then you will have to download it as follows (then repeat Step 6):
sudo apt update
sudo apt install git-all
7. After Step 6, the Workbench will have been installed. To check it out, close any FreeCAD application that is currently open, and the launch it again. You should see the downloaded workbench in the Workbench List. :)
8-) MFC Boy: the one and only! 8-)
colt45s1911a1
Post by colt45s1911a1 »
so, i see that the problem with the easy installing of workbenches has been around for quite some time, does anyone know if it may be fixed soon or should we just get used to downloading and loading them as explained ??
Update to 0.19_pre untill v0.19 is available for download (should be imminently)
Edit: locking topic
Locked
