We found a bug in the sketcher workbench. See post in german sub up from here
A user asked for help with a part of a ellipse as section for an revolve. After some attempts it came out, that after trimming a ellipse things went wrong.
Steps to repeat the problems:
- create a ellipse
- depending on which quadrant is trimmed away different errors show up: ellipse collapses to a vertikal or horizontal line or to a single vertex. Or the sketcher references to vertices which aren't exist anymore. Also undo creates ugly behaviour.
regards
Ticket #4419 - Trim of ellipse creates invalid constraints
Reason: Added ticket number to thread title (altered title to reflect ticket subject)
Re: Bug in sketcher WB - ellipse and trim tool
It seems that they are talking about FreeCAD 0.18.4, at least the first post is, Chris at least knows better than to worry about an old bug in an old release version (so perhaps he did test 0.19), it has to be tested (like all bugs) in the latest Dev version Currently FreeCAD 0.19.
For me it did go to a straight line the first time I tried it but undo worked perfectly and I could not get it to do that again, unless I used clip on the shorter of the two construction lines axes. The longer line would halve in length and recalculate the ellipse, and clicking on any 1/4 just removed that 1/4 as expected.
Now I just got the straight line thing again but undo is still working properly. There must be a more complex set of requirements to get this straight line error at least in 0.19. I will see if I can narrow it down...
OS: Ubuntu 18.04.5 LTS (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: 93bb9646c36a84efdc3be4e4ca60c7e0234a6233
Python version: 3.6.9
Qt version: 5.9.5
Thanks for the reply. Some more info.jmaustpc wrote: ↑Mon Aug 17, 2020 2:25 pmIt seems that they are talking about FreeCAD 0.18.4, at least the first post is, Chris at least knows better than to worry about an old bug in an old release version (so perhaps he did test 0.19), it has to be tested (like all bugs) in the latest Dev version Currently FreeCAD 0.19.
I'm on 0.18 as well as
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.22261 (Git) AppImage
Hash: 1c432fd6170b7904592a224194e42d3c566707a6
Python version: 3.8.5
auto removal of redundant constraints is on
avoid redundant auto-constraints is on
Unfortunately I forgot to copy the output of the console. From memory: sketch has malformed constraints.
Hope it helps
For me undo works, but I think I have finally found a way to get a straight line with the following error message in report view...
I created an ellipse with "centre, major radius, point" method in the positive xy quadrant. Then I selected the auto generated major radius point (opposite the major radius that I click to create), then select the origin and coincidence constraint, then use the trim tool one the higher left quadrant (see sreenshot), which then makes a straight line with the error message above. However if I click on any other quadrant first then it seems to work, although some time I get an error message even thought it worked but not always.
Daily PPA
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
01:21:10 Updating geometry: Error build geometry(0):
01:21:10 Invalid solution from DogLeg solver.
01:21:10 Invalid solution from LevenbergMarquardt solver.
Daily PPA
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
I had tested with the almost latest 0.19 and as far as I know nothing has changed in sketcher since.
Jim, you use the Levenberg-Marquardt solver. As this isn't the default, could you retry with the dogleg solver? I get the message
There was an issue with Levenberg-Marquardt not being able to solve some pretty simple sketches, but I'm not sure if it was fixed or not.
I had uploaded a file with an ellipse, just to make sure that different ways of creation don't play a role, I link it below. With that file I experience the following behaviour:
- opening the file and trimming the right lower quarter and then the left lower yields the error described above with the invalid constraints
- starting with trimming the right upper quarter yields different results, undo and trim again is usually not identical to first trim
- - it can remove the arc and create conflicting constraints - - it can collapse to a point - - it can collapse to a line - - it can collapse to a rather small (correct) variant of the trimmed ellipse - - it can look correct but is in fact unsolved OS: macOS High Sierra (10.13)
Version: 0.19.22246 (Git)
Hash: abd18ff88f7682e9b1160c36bb785b14a33473ef
Locale: C/Default (C)
ellipseTrim.FCStd
19:06:04 Updating geometry: Error build geometry(0):
19:06:04 Invalid solution from DogLeg solver.
ellipseTrim.FCStd
I may add that trimming such a quarter is non trivial, because the open ends of the arc must not be connected with coincidence constraints to the nds of the axes, they have to be point-on-objects.
Created issue #4419.
Re: Ticket #4419 - Trim of ellipse creates invalid constraints
Mod edit: Renamed thread with Ticket number and summary
