[FEATURE REQUEST] spreadsheet zoom
TomB19
Post by TomB19 »
I often wish I could shrink a spreadsheet, to get more on screen. Is there a way?
[Edit: I have created a feature request in the Bug Tracker, at Kunda1's request]
https://tracker.freecadweb.org/view.php?id=4410
TheMarkster
Re: Is there a way to zoom a spreadsheet view?
Post by TheMarkster »
There is a way to shrink the row height via python.
for ii in range(1,99):
    App.ActiveDocument.Spreadsheet.setRowHeight('A'+str(ii),1)
After running this in the python console, right click the document name in the tree and select Mark to recompute, then F5 to recompute.
TheMarkster wrote: Sat Jul 11, 2020 2:20 am There is a way to shrink the row height via python.
Would it merit a feature request to have a slider of a sort somewhere at the bottom of the spreadsheet dialog that scales the size of the spreadsheet ?
TheMarkster
Kunda1 wrote: Sat Jul 11, 2020 6:44 pm
I don't know. You can already adjust the row sizes individually. In the image below the red circle indicates the drag point.
Snip macro screenshot-46c9d2.png (4.56 KiB) Viewed 1760 times
TomB19
Post by TomB19 »
Thank you, TheMarkster. 8-)
For a few months, I was adding attributes to spreadsheets in a two column format. That would have been helpful, then.
That approach proved nonviable so I switched to a multi-column format. This has helped a lot.
I've attached a screen shot of the layout I use, these days. It's blurry because it's been heavily shrunk for forum upload (native 2560x1600 resolution).
Sometimes it would be nice to be able to control the size of the entire spreadsheet, something like the LibreCalc zoom slider at the bottom right (screen shot below, for those who haven't seen LibreCalc :mrgreen: ).
I doubt this feature is more important than any number of other things the team is working on, so I don't wish to request it.
resized_FC Screen Layout.png (115.86 KiB) Viewed 1741 times
LibreCalc
LibreCalc - zoom.png (1.71 KiB) Viewed 1741 times
TomB19 wrote: Sat Jul 11, 2020 8:06 pm Sometimes it would be nice to be able to control the size of the entire spreadsheet, something like the LibreCalc zoom slider at the bottom right (screen shot below, for those who haven't seen LibreCalc :mrgreen: ).
Yes, I was thinking of a slider like this one. I think it would be a nice UI/UX addition. For sure low priority but still good to have on the list
I'd imagine the need to use https://doc.qt.io/qt-5/qslider.html
Do you mind making a gif or screencast of the slider in action and posting to this thread ?
mario52
Post by mario52 »
hi
Kunda1 wrote: Sun Jul 12, 2020 12:29 pm Do you mind making a gif or screencast of the slider in action and posting to this thread ?
adaptation of the macro openBrain and awei adding extra info in statusbar
modify only the colon A to Z
and the row 1 to 50
for modify the text size .. ??? .. other gourou Python
##https://forum.freecadweb.org/viewtopic.php?f=22&t=48217#p413246
##12/07/2020
##mario52
##worked and based on the openBrain and awei snippet
import PySide2
from PySide2 import QtWidgets
import FreeCAD
def sliderVal(value):
    try:
        for i in range(26):                 # for 26 colon A .. to .. Z
            for ii in range(1, 50 + 1):     # for 50 row   1 .. to .. 50
                #print(chr(i+65)+str(ii))
                cellule = chr(i+65)+str(ii)
                App.ActiveDocument.Spreadsheet.setRowHeight(cellule, value)
                App.ActiveDocument.Spreadsheet.setColumnWidth(cellule, value * 4)
        App.ActiveDocument.Spreadsheet.touch()
        App.activeDocument().recompute()
    except Exception:
        None
pb = PySide2.QtWidgets.QSlider()
pb.setOrientation(PySide2.QtCore.Qt.Horizontal)
pb.valueChanged.connect(sliderVal)
Gui.getMainWindow().statusBar().addWidget(pb)
pb.show()
mario
mario52 wrote: Sun Jul 12, 2020 6:02 pm hi
:D
mario52 wrote: Sun Jul 12, 2020 6:02 pm adaptation of the macro openBrain and awei adding extra info in statusbar
:heart:
This is awesome!
mario52 wrote: Sun Jul 12, 2020 6:02 pm for modify the text size .. ??? .. other gourou Python
Yes! We need another python guru to chime in here for sure.
TheMarkster
A few modifications to Mario's macro.
##12/07/2020
##mario52
import PySide2
import FreeCAD
sheet = None
def getSelected():
    """returns a QModelIndex object or None if none are selected
   use [0] to get at first cell in the selection
   use [0].row() to get first cell's row
   use [0].column() to get first cell's column
   use [-1] to get last cell in the selection
    global sheet
    from PySide import QtGui
    mw=FreeCADGui.getMainWindow()
    mdiarea=mw.findChild(QtGui.QMdiArea)
    subw=mdiarea.subWindowList()
    sel = Gui.Selection.getSelection()
    name=""
    if sel:
        name = sel[0].Name
    for i in subw:
        if i.widget().metaObject().className() == "SpreadsheetGui::SheetView":
            if not name == i.windowTitle().replace('[*]',''):
                continue
            sheet=Gui.Selection.getSelection()[0]
            return i.widget().findChild(QtGui.QTableView).selectedIndexes()
    return None
    try:
        ranges = getSelected()
        if not sheet:
            return
        for rr in ranges:
            cellule = chr(rr.column()+65)+str(rr.row()+1)
            sheet.setRowHeight(cellule,value)
        sheet.touch()
    except Exception:
        None
pb.setMinimum(1)
pb.setMaximum(200)
pb.show()
Changes:
1) only change row heights
2) get preselected cells and apply row height to only those rows
3) set minimum to 1 (0 hides row entirely) and maximum to 200
4) allow for operation on selected spreadsheet (but it must be selected in the tree, not just in the sheet view)
Things to do:
1) add/show the slider only when the sheet view is active (unless it already exists), then hide/remove it
2) incorporate somehow into FreeCAD main (maybe modify src/Mod/Spreadsheet/InitGui.py?)
