0.19 Part Design - Only the last feature visible
cram
Post by cram »
Version: 0.19.19955 (Git)
Hash: fd907d6d9789f71007b8d0177d167f1de82629b8
Python version: 3.8.2
Locale: English/Australia (en_AU)
Hi again,
I have drawn a sketch and revolved that to create a solid, then created a datum point, added a additive sphere and attached it to the datum point however only the sphere is visible. If I then go to the tree and select the Revolution and set it to visible the Sphere becomes invisible and vice versa if I go back to it and set it to visible.
Coulter_Hub_Bearing2.FCStd
(13.46 KiB) Downloaded 27 times
Re: 0.19 Part Design - Only the last feature visible
A PartDesign body describes only one contiguous body. If the first and the second feature don't overlap it is not a valid body and one of the separate solids is discarded. Other features raise an error message in that case.
If you want to model a bearing in a single body it wouldn't work anyway, because it's a single solid. So you could simply make the sphere slightly larger, e.g. by increasing the radius by 0.01mm.
cram
Post by cram »
chrisb wrote: Sun Apr 12, 2020 11:40 pm A PartDesign body describes only one contiguous body. If the first and the second feature don't overlap it is not a valid body and one of the separate solids is discarded. Other features raise an error message in that case.
Thanks Crisb. So much to learn, what you describe I think I've read before but forgotten.
cram
Post by cram »
chrisb wrote: Sun Apr 12, 2020 11:49 pm If you want to model a bearing in a single body it wouldn't work anyway, because it's a single solid. So you could simply make the sphere slightly larger, e.g. by increasing the radius by 0.01mm.
Increasing the sphere diameter doesn't have the desired effect.
I'm sorry, could you point in me the direction of how I should model the bearing so it is not a single solid?
Edit: I think I just need to create in a new body. Apologies.
freedman
Post by freedman »
I simple bearing is made up of maybe these.
Ball bearing
inner race
outer race
retainer
clip
Each of the above would be a body. Planning on an array for the balls and a maybe a mirror of the retainers and clips.
Someone last year did a really well detail bearing, you might try to find that posting.
cram wrote: Mon Apr 13, 2020 1:29 am Increasing the sphere diameter doesn't have the desired effect.
Just for the sake of completeness: it has the desired effect: I have only changed the radius to 5.001:
Snip macro screenshot-faa9f9.png (25.7 KiB) Viewed 581 times
Coulter_Hub_Bearing2_cb.FCStd
(32.3 KiB) Downloaded 21 times
cram
Post by cram »
Thank you again. For some reason it didn't seam to work for me earlier, but I'm guessing that I didn't follow through on it earlier in a correct manner.
