- Create a new document, select PartDesign WB
- Add a sketch (you can just let it empty)
- Create a DatumPlane (locate it at any position)
- Try to enter as expression for DatumPlane/AttachmentOffset/Angle the following :'90°-atan(Sk' => You'll notice first that 'Sketch' is only proposed when you enter the 'k', then that if you select 'Sketch' proposal with down arrow, it is replaced by 'SSketch' in the expression (doubled 'S')
Thx for confirming.
As a sidenote, I get lot more problems with expressions in this file. Expressions using '°' just vanished, and some had the object reference cleared (eg. 'Sketch.Constraints.xxx' was saved as '.Constraints.xxx') but I'm not able to reproduce it ATM.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19461 (Git)
Hash: da71719896847b0e2a5716e7afb5d4cb4b326990
Python version: 3.6.8
Qt version: 5.12.1
Locale: French/France (fr_FR)
