[ Ticket #4236 Recompute issue ] Placement.Rotation.Axis and non unit vector?
Roy_043
Post by Roy_043 »
In the attached file the placement of Body001 is linked to that of Body through formulas.
Everything seems to work fine except for one thing. I can change the rotation axes of Body to values that do not correspond to a unit vector. But in that case the rotation axes of Body001 are recalculated to unit vector values, resulting in a different placement.
This behavior seems strange.
Test:
Change the rotation axes of Body to: 1,0,1.
Result for the rotation axes of Body001: 0.71,0,0.71.
OS: Windows 8.1 (6.3)
Version: 0.19.18946 (Git)
Hash: 0175008ceba01666449657086ca036fc59e0e6c7
Python version: 3.6.8
Qt version: 5.12.1
PlacementTest.FCStd
(17.27 KiB) Downloaded 32 times
Vincent B
Re: Placement.Rotation.Axis and non unit vector?
Post by Vincent B »
Axe data are just a vector, its must be ok with 0.71 0 0.71
...but I've got 0.69 0.00 0.72... :shock: something wrong.
Version: 0.19.18990 (Git)
Hash: e499f384240196c415f207520bfbcb8df9d1b0d2
Qt version: 5.12.1
Locale: French/France (fr_FR)
openBrain
Post by openBrain »
Rotation are internally stored as quaternions, so indeed you'll get normalized vector even if you entered a non one. But this should not change the placement.
Roy_043
Post by Roy_043 »
@openBrain, you are probably right, and this may actually turn out to be a confusing recompute issue.
After changing the axes of Body to 1,0,1 Body001 has to be recomputed 5 times to visually adopt its correct placement.
openBrain
Post by openBrain »
I took some time to open the file, and there is definitely something weird.
I ran below snippet :
old = App.ActiveDocument.Body001.Placement.Rotation.Axis
for i in range(2,100):
    App.ActiveDocument.Body001.touch()
    print("Iteration %i : %s" % (i, App.ActiveDocument.Body001.Placement.Rotation.Axis))
    if old == App.ActiveDocument.Body001.Placement.Rotation.Axis:
        print("Steady state achieved")
        break
And it takes 26 iterations of recomputing (including the 1st automatically performed by FC) to get a steady state !!! :!:
Unfortunately I can't get no further clue about what happens.
Roy_043
Post by Roy_043 »
Thanks for testing. Weird indeed. I'll check the situation in V0.18.
Roy_043
Post by Roy_043 »
Somehow the formulas applied in V0.19 are missing when the file is opened in V0.18 (known issue?).
But after creating a similar model in V0.18 I find that the recompute issue also occurs there.
OS: Windows 8.1
Word size of FreeCAD: 32-bit
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
PlacementTest_V018.FCStd
(15.95 KiB) Downloaded 19 times
openBrain
Post by openBrain »
I can reproduce with a minimal example with just a cube and a cylinder... :)
Let's ask to who knows. ;)
wmayer wrote: Ping
@wmayer, easy fix or deserve a ticket ?
openBrain wrote: Fri Dec 27, 2019 3:50 pm I can reproduce with a minimal example with just a cube and a cylinder... :)
wmayer wrote: Ping
Go ahead and open a ticket please. I think there might be something wrong in the expression engine.
It's true that on low-level when calculating with the quaternions the axes are normalized but the Rotation class stores the original axis coordinates and angle so that the property editor will show the original values instead of the normalized values.
Roy_043 wrote: Fri Dec 27, 2019 2:03 pm Somehow the formulas applied in V0.19 are missing when the file is opened in V0.18 (known issue?).
That can be expected. The new expression engine in 0.19 uses new syntax, wich probably (in most cases) cannot be interpreted in 0.18.
