Ticket #4217 - python speedup suggestion: avoid use of 'if mykey in mydict.keys()'
apelleti
Post by apelleti »
https://www.freecadweb.org/tracker/view.php?id=4217
I see ~70 occurrences in FreeCAD of a simple python coding problem that causes a big degradation in performance, described below.
Doing a python dictionary hash lookup the recommended way:
# test if 'somekey' is in dictionary mydict. order-1
if "somekey" in mydict:
    do_something()
Doing a python dictionary hash lookup the wrong way:
# walk the dictionary to compile an unsorted list of keys: order-N,
# then brute force search for desired key in this unsorted set: order-N
if "somekey" in mydict.keys():
    do_something()
Performance comparison:
# good way:
import random
mydict={k: random.random() for k in range(200000)}
for i in mydict:
    if i not in mydict:
        print("FAIL!")
Runtime=0.07 seconds to test 200k keys exist in the dictionary of 200k entries.
# bad way:
import random
for i in mydict:
    if i not in mydict.keys():
        print("FAIL!")
Runtime=11min 29sec.....10000 times slower!! :-(
You can do a simple search of the whole codebase for occurrences of this probelm using:
 find . -name "*.py" | xargs egrep "if.* in .*\.keys"
Reason: Added ticket number to thread title
vocx
Re: python speedup suggestion: avoid use of 'if mykey in mydict.keys()'
Post by vocx »
apelleti wrote: Fri Dec 06, 2019 2:35 pm ...
Premature optimization is not a good thing. Sure this could be changed but is it really a problem right now?
Also, since you seem to be interested in efficiency, I don't understand why people use xargs with find. Find can already run commands with the -exec option.
This creates a single command with many arguments, which is efficient.
find . -name "*.py" -exec egrep "if.* in .*\.keys" {} +
This runs the command for each found file, so it is less efficient.
find . -name "*.py" -exec egrep "if.* in .*\.keys" {} \;
Michel59263
Post by Michel59263 »
Is it realy a "premature optimisation" ?
May be it's a "bad" use of python which should be corrected and explained.
Michel
openBrain
Post by openBrain »
IMO, as this is a pure Python concern, it is easy to patch & test locally.
So one could easily find the occurrences, patch them and test if it doesn't cause troubles.
DeepSOIC
Post by DeepSOIC »
there's a remarkable number of these occurrences in importIFC. These for sure must be corrected, I'm almost certain they can become a performance bottleneck on very large projects. As for the rest, I suspect they are insignificant in their impact, but it's worth correcting them too. There are a few obvious likely-false-positives in the list in the bug tracker:
./src/Mod/Material/materialtools/cardutils.py: if k in registed_cardkeys:
./src/Mod/Material/materialtools/cardutils.py: if (k not in used_and_registered_cardkeys) and (k not in used_and_not_registered_cardkeys):
The rest seem legit at first glance.
DeepSOIC
Post by DeepSOIC »
openBrain wrote: Fri Dec 13, 2019 10:16 am IMO, as this is a pure Python concern, it is easy to patch & test locally.
That's only for "someone" who knows freecad all through. I've looked over the list, and off the top of my head, I don't know how to trigger any single one of them.
openBrain
Post by openBrain »
DeepSOIC wrote: Fri Dec 13, 2019 12:01 pm there's a remarkable number of these occurrences in importIFC. These for sure must be corrected, I'm almost certain they can become a performance bottleneck on very large projects.
Like this ? https://forum.freecadweb.org/viewtopic.php?f=39&t=41600 :)
I already posted a patched version in the ticket. ;) It will prevent such false-positive.
DeepSOIC wrote: Fri Dec 13, 2019 12:04 pm That's only for "someone" who knows freecad all through. I've looked over the list, and off the top of my head, I don't know how to trigger any single one of them.
Very probably there are more time spent verifying than patching. ;)
