FreeCAD 0.18 misbehavior in virtual machine
I am running Freecad on a virtual machine of Win10 (Win10 as a guest on VirtualBox 6.0.6 running on a Linux host RH rl7).
Freecad 0.17 was running perfectly this way (and all versions before too). For the new version 0.18 I get a very strange behavior. It starts up normally in the splash screen, however, if I start a new project "+ Create new ..." (or I open an existing one), the new window content is just a black surface. If I hover of the place where the menu is supposed to be, the corresponding dropdown will open, but the rest of the window is still black.
The following screenshot shows the situation (the splash screen (left) together with the project window (right), I have started a second instance), an opened drop-down menu is also shown (in project window on the right):
Are there new prerequisites for the 0.18 versions concerning the graphic card / 3D acceleration / ... ? Is there a place where this could be changed? I did not find any preference item, where I could change such prerequisite mode.
Any other Idea, what is going wrong here?
Thanks a lot
Manuel
Thanks a lot
Manuel
Re: FreeCAD 0.18 misbehavior in virutal machine
Just out of curiosity - why would you run it that way?
We have seen similar issues on non virtual computers where the graphics card driver was the culprit. You can try a newer or older driver.
Re: FreeCAD 0.18 misbehavior in virtual machine
The responsible change that could explain the behaviour is the move from Qt4 to Qt5. Qt5 has a module QtOpenGL kept for backward compatibility but it's recommended not to use it and instead to port old code to the new API. At the beginning when we moved to Qt5 we used this module but it caused several problems and we then ported our code using the recommended API.Are there new prerequisites for the 0.18 versions concerning the graphic card / 3D acceleration / ... ?
Under the hood the implementation of OpenGL support in Qt5 has changed a lot and it's hard to say what at the end is responsible if something doesn't work. But as said above in most cases it's the graphic driver that causes problems.
For more information also have a look here: https://doc.qt.io/qt-5/windows-requirem ... cs-drivers Maybe you can get it to work by setting the variable QT_OPENGL
... all right. Thanks a lot for the information. I will have a closer look into the subject. I will get back, if I find a solution.wmayer wrote: ↑Fri May 03, 2019 11:17 amThe responsible change that could explain the behaviour is the move from Qt4 to Qt5. Qt5 has a module QtOpenGL kept for backward compatibility but it's recommended not to use it and instead to port old code to the new API. At the beginning when we moved to Qt5 we used this module but it caused several problems and we then ported our code using the recommended API.Are there new prerequisites for the 0.18 versions concerning the graphic card / 3D acceleration / ... ?
wmayer wrote:The responsible change that could explain the behaviour is the move from Qt4 to Qt5. Qt5 has a module QtOpenGL kept for backward compatibility but it's recommended not to use it and instead to port old code to the new API. At the beginning when we moved to Qt5 we used this module but it caused several problems and we then ported our code using the recommended API.Are there new prerequisites for the 0.18 versions concerning the graphic card / 3D acceleration / ... ?
This above explanation would be great to put in the Known Issues thread or wiki page of 0.18-0.19_pre
I will add it (later).
brandneran
I have to run Freecad on a virtual computer too and I have the same problem. The QT.. variable did not help. Also I didn´t find any possibility to update drivers to get it work.
In my case the physical machine is a brand new HP-Server with windows 2016 server on it and the virtual computer is a windows 2016 server too.
