Ticket #3834 - Loss of coordinate systems during .stp (AP214) import/export
whocares
Post by whocares »
OS: Windows 10
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
iam new to FreeCAD and run into an issue.
I have one Part with multiple coordinate systems to build a millingtool.
The coordinate systems be called PCS,MCS,CSW.
If i set them and export them to .stp (AP214) they got lost.
Also if i set them in a other CAD-System they will not be imported.
Thanks for usefull suggestions.
Reason: Added ticket number to thread title
Re: Loss of coordinate systems during .stp (AP214) import/export
Where and how do you set your coordinate systems? Is a "coordinate system" a special entity in the STEP format?
whocares
Post by whocares »
Source is Siemens NX12
2019-02-12 12_01_39-Window.png (40.29 KiB) Viewed 2352 times
Picture shows 3 different coordinate systems.
Exporting them from NX to .stp and reimporting to NX works fine.
Importing the .stp to FreeCAD, they are gone.
Maybe the Siteadmin can move this to the right Topic.
Example STEP File added.
model2.stp
Step with named coordinate systems PCS,MCS,CSW -> #4082=AXIS2_PLACEMENT_3D('MCS',#5744,#4567,#4568);
(369.86 KiB) Downloaded 71 times
Export.stp
(48.92 KiB) Downloaded 43 times
Jee-Bee
Post by Jee-Bee »
This is not a announcements or new Feature(s).
So you should ask in the help forum or if it is a bug in the open discussion forum. Also add your (example) step file.
easyw-fc
Post by easyw-fc »
whocares wrote: Tue Feb 12, 2019 12:03 pm Source is Siemens NX12
it seems the method is supported in OCC STEP kernel
https://www.opencascade.com/doc/occt-6. ... ement.html
When opening the file in a text editor then you will find a few hundred AXIS2_PLACEMENT_3D elements but only three of them has names. So, I guess it's up to the application to only consider them.
Nevertheless, the ignorance of the AXIS2_PLACEMENT_3D is not a bug but might be a feature to implement for v0.19 (if even possible).
whocares
Post by whocares »
wmayer wrote: Wed Feb 13, 2019 11:05 am When opening the file in a text editor then you will find a few hundred AXIS2_PLACEMENT_3D elements but only three of them has names. So, I guess it's up to the application to only consider them.
Thank you for your Response.
Iam not that familiar with FreeCAD, CATIA exports these DatumPlanes the same Way.
I have added an Example Step File with only the DatumPlanes in it.
Maybe its usefull.
DatumPlaneOnly.stp
(3.55 KiB) Downloaded 53 times
I found a way to find the named placements:
    Handle(Interface_InterfaceModel) Model = aReader.Reader().Model();
    Standard_Integer nb = Model->NbEntities();
    for (Standard_Integer i = 1; i <= nb; i ++) {
        Handle(Standard_Transient) enti = Model->Value(i);
        if (enti->IsKind(STANDARD_TYPE(StepGeom_Placement))) {
            Handle(StepGeom_Placement) plm = Handle(StepGeom_Placement)::DownCast(enti);
            if (plm->Name()->Length() > 0) {
               // do something with it
The question however is what does OCCT's OCAF framework with them? I am not sure that the objects are transferred from the STEP model to the OCAF document. And this makes it tricky to add them to a FreeCAD document.
Btw, the file Export.stp shows the data of the screen shot you posted. Also it contains 45 AXIS2_PLACEMENT_3D objects but none of them has the labels "PCS", "MCS" or "CSW". Would it be possible to upload the STEP file that is shown in the screen shot that includes the named AXIS2_PLACEMENT_3D objects?
Thanks!
whocares
Post by whocares »
Example uploaded.
Thank you for the effort.
exportwithnamedplanes.stp
(35.06 KiB) Downloaded 58 times
Here is a code snippet to add the placements after loading the file:
plm=App.ActiveDocument.addObject("App::Placement","CSW")
plm.Placement.Base=App.Vector(31.8244952147467,33.7921260930763,-162.824495214746)
plm=App.ActiveDocument.addObject("App::Placement","MCS")
plm.Placement.Base=App.Vector(15.925,31.8500000000002,-82.48178698)
plm=App.ActiveDocument.addObject("App::Placement","PCS")
plm.Placement.Base=App.Vector(7.105427357601E-15,1.04449782156735E-12,1.4210854715202E-13)
It respects only the position but not the orientation.
