To support an equation, there must be a direct relation between the value of an input field and a property of some object.
Placement panel: all input fields should have expressions like they have in the property panel.
Hard to do, as the placement dialog has some values that don't directly relate to properties. Placement dialog offers things like center of rotation, yaw-pitch-roll values and "apply incremental changes" checkbox, which break/don't have a direct relation to properties.
chrisb wrote: ↑Tue Jan 29, 2019 12:33 am
PartDesign: additive and subtractive primitives, their individual values such as radius, height, width, length as well as pitch, yaw, roll
Doable, except for roll-pitch-yaw. Roll-pitch-yaw is a little difficult beast, it may be possible to bind expressions to them, but I'm not sure.
Part.Extrude; all numeric input fields.
Part.Revolve; all numeric input fields.
Doable. I think...
Part.Thickness.
Already has one, doesn't it?
Part.Mirror; x, y, z
Part.Fillet; start and end radius. This might be difficult, as the values are somehow copied to a list.
Part.Chamfer; same situation as with fillets.
probably doable, but I'm not sure.
Please don't assume that I have just promised to add that myself
