Bug: how to lose your origin
MIngB
Post by MIngB »
In my drawings is an quite annoying Origin problem.
Sometimes Origins where not where they should be and disappeared by chance.
I finally tracked it down to:
Case: Lose Origin
- create a Body with a Box
- toggle Body inactive
- hold CTRL and mark Body and Box (not Origin)
- press CTRL-C and CTRL-V
- delete new created Body001
- enjoy your Body without an origin
Case: Lose Origin content
- hold CTRL and mark Body, Box and Origin
- enjoy your first Body with an empty origin
Is there a way to migrate my (quite big) drawings to give each Body an own Origin?
OS: Gentoo/Linux
Version: 0.18.15609 (Git)
Build type: Debug
Branch: (HEAD detached at a14af0f2b)
Hash: a14af0f2bd26f980d71be80a799ee48127bc7619
Python version: 3.6.5
Qt version: 5.11.1
PartDesign_CP4_Bug.FCStd
(10.19 KiB) Downloaded 44 times
freedman
Re: Bug: how to lose your origin
Post by freedman »
Do you mean that you don't have origins for each body in your big drawing? Image attached, what you should get with every Body created.
MIngB
Post by MIngB »
Just open the attached file in my first post and delete Body001.
Than you should have an Origin without geoFeatures...
I'm diving into the code right now..
doing copies like i described you get:
    <Objects Count="12">
        <Object type="PartDesign::Body" name="Body" />
        <Object type="App::Origin" name="Origin" />
        <Object type="App::Line" name="X_Axis" />
        <Object type="App::Line" name="Y_Axis" />
        <Object type="App::Line" name="Z_Axis" />
        <Object type="App::Plane" name="XY_Plane" />
        <Object type="App::Plane" name="XZ_Plane" />
        <Object type="App::Plane" name="YZ_Plane" />
        <Object type="PartDesign::AdditiveBox" name="Box" />
        <Object type="PartDesign::AdditiveBox" name="Box001" />
        <Object type="App::Origin" name="Origin001" />
        <Object type="PartDesign::Body" name="Body001" />
    </Objects>
instead of
    <Objects Count="18">
        <Object type="App::Line" name="X_Axis001" />
        <Object type="App::Line" name="Y_Axis001" />
        <Object type="App::Line" name="Z_Axis001" />
        <Object type="App::Plane" name="XY_Plane001" />
        <Object type="App::Plane" name="XZ_Plane001" />
        <Object type="App::Plane" name="YZ_Plane001" />
    </Objects>
which shows, that GeoFeatures of Origin and Origin001 are shared in the first case.
These seem to be deleted by deleting Box001
Copying as I described in my first post you could also share the same Origin...
I believe there is something to improve on Copying Bodies as well as deleting Bodies eg. Origins -> There should be a check if they are shared
I had seen this recently: a body with a missing plane, and I had no idea how this could have happened. So it's good to see a way to reproduce. Would you create a ticket with a link to this discussion and vice versa?
MIngB
Post by MIngB »
Bug reported in Mantis
Thank you.
DeepSOIC
Post by DeepSOIC »
The problem is, copying bodies (as well as Parts and Groups) isn't well supported yet. You'll likely encounter a lot of weirdness around that.
