[Solved] Drawing on top of imported PNG image creates Fatal error.
hhassey
Post by hhassey »
Imported an image in a plane, proceed to draw on top of that image (pretty common for architectural work trying to measure wall areas) then saved the work, when you re open the file everything is messed up. and creates this error message:
Fatal Error at file /home/Test_File.fcstd, line 64, char 53
Invalid Document.xml: expected entity name for reference
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 31 (X_GrabKeyboard)
  Resource id: 0x0
These are the steps to reproduce:
1.- Open new Document
2.- Switch to Image WB.
3.- Push "Createe Planar image in 3D space" Select a png image. on plane x-y
4.- Set the image position to -1m
5.- Switch to the Draft WB
6.- Draw a "Multiple point Draft Wire" on top of the image, don't close it
7.- Save your work and Re open
System Information:
OS: Debian GNU/Linux 9.5 (stretch)
Version: 0.18.14959 (Git)
Build type: Debug
Hash: ff05101b68dc9a7d1e70dd69544f14ac8598a433
Python version: 2.7.13
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
A bug on the tracker system has been issued:
https://www.freecadweb.org/tracker/view.php?id=3632
hhassey
Re: Drawing on top of imported PNG image creates Fatal error.
Post by hhassey »
FOUND THE BUG, the png image name had an "&" in it and made FreeCAD crash
hhassey wrote: Wed Oct 10, 2018 4:42 pm FOUND THE BUG, the png image name had an "&" in it and made FreeCAD crash
@hhassey wmayer committed a fix for this in git commit 22ddbe0f8d6
Can you test and confirm and prepend [Solved] to this forum thread please...? Thanks!
hhassey
Post by hhassey »
Confirmed, It works perfectly now.
Thanks for the hard work :)
