[Solved] Spreadsheet issue with App::PropertyFloatList
TheMarkster
Post by TheMarkster »
*** Issue now resolved with https://github.com/FreeCAD/FreeCAD/comm ... 70c4ca68e0 ***
The spreadsheet does not get updated when the contents of App::PropertyFloatList are updated.
To recreate:
Create a feature python object and add a property of type App::PropertyFloatList to it. Add 3 values to it using the property editor: 0.0,1.0,2.0. Create a new spreadsheet. In cell A1 enter the reference to one of the floats in the property list. Update the list. Spreadsheet cell does not update.
Create the feature python object:
obj = App.ActiveDocument.addObject("App::FeaturePython","test")
obj.addProperty("App::PropertyFloatList","float")
Open "float" property (click the ... in the property view) and add 3 values:
0.0
1.0
2.0
= test.float[2]
Cell A1 now shows 2.0 (all go so far)
Open the "float" property again and change it to:
0.0
1.0
2.2
Recompute the document.
Expectation: spreadsheet cell A1 updates to 2.2, but it doesn't update (stays at 2).
This same technique works with PropertyFloatList items when referencing from sketcher constraints and from other properties, so the change signal is getting emitted when the property changes. The signal that the float list property was updated is either not being received by the spreadsheet module or isn't being acted upon.
Edit: forgot to include info
OS: Windows 10
Version: 0.18.14784 (Git)
Hash: ac21bcc35c56b360e03c646f5cfdcf15e5769717
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
DeepSOIC
Re: Spreadsheet issue with App::PropertyFloatList
Post by DeepSOIC »
confirmed.
OS: Windows 10
Version: 0.18.14495 (Git)
Hash: c717d1121d888fe6cfbd8971b5f59311a34b37bc
Qt version: 4.8.7
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
eivindkvedalen
Post by eivindkvedalen »
TheMarkster wrote: Sat Sep 22, 2018 9:29 pm The spreadsheet does not get updated when the contents of App::PropertyFloatList are updated.
Confirmed. Please register this in the bug tracker.
Eivind
TheMarkster
