teigha file converter
Rayg
Post by Rayg »
I have just downloaded and installed freecad and want to import a DWG file. I have searched for the teigha converter but the page is not available. What do I do now?
Re: teigha file converter
Moved to help forum.
NormandC
Post by NormandC »
Seems like Teigha File Converter was renamed to ODA File Converter.
https://www.opendesign.com/guestfiles/o ... _converter
NormandC
Post by NormandC »
I just tested it on Ubuntu 18.04 and it works. We'll have to revise the wiki and change all mention of Teigha to ODA. FreeCAD's DWG import-export preferences should be changed as well...
NormandC
Post by NormandC »
I think I updated all the places in the wiki where Teigha was mentioned and updated the download link, including in all the translated pages. :?
Kunda1 wrote: ping
Would you be willing to make a PR to update the text string in the Import-Export/DWG preferences? Maybe replace the existing text string:
Path to Teigha File Converter
With
Path to ODA (formerly Teigha) File Converter
Thanks.
NormandC wrote: Sun Sep 09, 2018 5:14 pm I think I updated all the places in the wiki where Teigha was mentioned and updated the download link, including in all the translated pages. :?
Kunda1 wrote: ping
With
Thanks.
Done. https://github.com/FreeCAD/FreeCAD/pull/1655
Though as the PR says, this is just a cosmetic fix. The Teigha binary path hasn't been altered and may need to be conditionally modified eventually...
NormandC
Post by NormandC »
Thanks.
FYI after installing the .deb package on Ubuntu, the executable's path is /usr/bin/ODAFileConverter. Looking at the extracted RPM file, it seems to be installed under /usr/local/bin/ODAFileConverter.
I downloaded the 64B .msi installer for Windows and extracted it... I can't tell where it installs, only that the executable is called ODAFileConverter.exe.
GeneFC
Post by GeneFC »
The default installation location in Windows for the source "ODAFileConverter_QT5_vc14_amd64dll.msi" downloaded today (2018/9/9) is
C:\Program Files\ODA\ODAFileConverter_title 19.8.0\
but it can be changed by the user if desired.
Gene
Can't access the report issue page on the tracker ATM making a reminder to open a ticket for the remainder of this issue
Keep remembering to do this task while on mobile and each time remember how crappy it is to use mantisbt on mobile. Normand, do you mind opening a ticket to track the remainder of this issue ?
