Issue #5782 - Possible bug with v0.20dev (was FC0.17) Part Design WB boolean function
nikisteen
Post by nikisteen »
Hi All,
I am fairly new to FreeCad and have been playing around with the new Part Design workbench of FC0.17. I see some strange behavior from the boolean operation. In the attached simple example I have a boolean operation which combines a sphere and a box with a cylinder. If I offset the sphere by 8mm in the Y axis, then it moves as expected. But when I offset the sphere by 9mm, it disappears (see attached images). It still intersects the rod, so I think it should still be visible. Are other people also seeing this behavior? If so, is this a bug or is it a misunderstanding on my side?
Thanks to all the people working hard to make this software available!
Niki
My FreeCad version info:
OS: Windows 10
Version: 0.17.13488 (Git)
Hash: 2891173923bcecaace64e0544f5773facbdef436
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.1.0
Locale: English/SouthAfrica (en_ZA)
BoolTest.FCStd
(16.07 KiB) Downloaded 32 times
Re: Possible bug with FC0.17 Part Design WB boolean function
I can confirm in the current stable - which you should use as well.
OS: Mac OS X
Version: 0.17.13509 (Git)
Branch: tag: 0.17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Qt version: 5.10.1
OCC version: 7.2.0
DeepSOIC
Post by DeepSOIC »
I can see the problem in Part workbench:
booltest_Part.FCStd
(5.73 KiB) Downloaded 23 times
It may look ok at first, but the fusion failed to merge the solids into one.
Selected document object:
  Name = Fusion001
  Label = Fusion001
  Is placement/array = False
Structure:
Compound (2 objects):
    Solid (1 shells)
    Solid (1 shells)
OS: Windows 8
Qt version: 4.8.7
OCC version: 7.1.0
Locale: Russian/RussianFederation (ru_RU)
So it is likely an OCC problem. You can put it into tracker nonetheless.
NormandC
Post by NormandC »
EDIT: aw shucks, DeepSOIC was faster than me. :D
Hey, try to move the sphere more than -5.1 mm in the X axis.
Apart from that, were you using primitives in separate bodies just to test Booleans? Because you can simply add them directly in the host Body.
Doing it differently (sphere created with a revolved sketch), I'm seeing similar issues. OCC kernel related or PD bug? We might want to compare with simple Part primitives.
BoolTest_normandc1.FCStd
(31.6 KiB) Downloaded 31 times
DeepSOIC
Post by DeepSOIC »
And, as usual, I could make it work by rotating something. Rotating cylinder didn't help, but rotating the sphere around X axis by 20 degrees did the trick.
  Name = Fusion001
  Label = Fusion001
Structure:
Compound (1 objects):
    Solid (1 shells)
booltest_workaround.FCStd
(12.5 KiB) Downloaded 31 times
NormandC
Post by NormandC »
I tried rotating, but I was doing it by 90-degree intervals... Too much.
nikisteen
Post by nikisteen »
So it looks like a bug, then. I know that I do not need a boolean to do what the example shows. I had the problem appear in a more complex design, but I then reduced it to this simple example. Should I submit this on the issue tracker?
Thanks!
Niki
OP created ticket issue #3425
Testers needed to see if issue is fixed per reports that it is: issue #3425
Shalmeneser
Post by Shalmeneser »
* Opening the file : sphere + cube (but not the cylinder)
* Redoing the Boolean union (suppress, select, union) : sphere + cube + cylinder
OS: Linux Mint 20.3 (MATE/mate)
Version: 0.20.27008 (Git) AppImage
Branch: (HEAD detached at 9162733)
Hash: 91627338a44371fe9a8e815b4900f62558af98a1
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: French/France (fr_FR)
Capture du 2022-01-15 17-59-20.png (24.31 KiB) Viewed 1145 times
