Cross section river profiles
CanisLupus
Re: Cross section river profiles
Post by CanisLupus »
Thank, now it works. :)
CanisLupus
So does someone has an idea how I can create such profile drawings...
[url=https://picload.org/view/drcwgall/examp ... e.jpg.html]
...from the sucessfull imported data?
microelly2
Post by microelly2 »
Look at TechDraw or drawing WB
an other way:
in Draft there is a shape2dView method to get mappings into the drawing plane
So you can compose your drawing
http://freecadbuch.de/doku.php?id=blog: ... e_pyramide
chakkree
Post by chakkree »
I'm using python macro for reading data and generate the SVG string, then insert to ViewSymbol in TechDraw.
RiverCrossSectionSVG.py
import csv
import tempfile
from FreeCAD import Vector
from xml.etree import ElementTree as et
from math import sqrt
def getBorder(w,h):
    return '''<svg xmlns="http://www.w3.org/2000/svg" width="%d" height="%d" viewBox="0 0 %d %d">
 <rect x="10" y="10" width="%d" height="%d" stroke="black" stroke-width="0.5" fill="none"/>
<text x="10" y="%d" font-size="4">Department of Civil Engineering, Southeast Asia University, Thailand</text>
</svg>
'''%(w,h,w,h,w-20,h-20, h-5)
if open.__module__ in ['__builtin__','io']:
    pyopen = open # because we'll redefine open below
templatefilehandle,templatefile = tempfile.mkstemp(suffix=".svg")
of = pyopen(templatefile,"wb")
of.write( getBorder(297,210) )
of.close()
path = 'D:\\Data\\RiverCrossSection\\'
fName = path+'example_data.csv'
CrossSection = {}
with open(fName, 'rb') as csvfile:
    data = csv.reader(csvfile, delimiter=',')
    count = 1
    for row in data:
        #Msg(row); Msg('\n')
        if count>1:
            name = row[0]
            str1 = name.split('q')
            id = str1[0]
            pointName = str1[1]
            x  = row[1]
            y  = row[2]
            z  = row[3]
            pointData = (x,y,z)
            if CrossSection.has_key(id):
                #CrossSection[id].append( pointData )
                CrossSection[id][pointName]= pointData
            else:
                pointData = {pointName:pointData}
                CrossSection[id] = pointData
        count+=1
Msg(CrossSection); Msg('\n')
# Find Min
minX = 10000000
minY = 10000000
minZ = 10000000
for iSection in CrossSection:
    #Msg(iSection); Msg('\n\n')
    #Msg(CrossSection[iSection]); Msg('\n\n')
    for iPoint in CrossSection[iSection]:
        #Msg(CrossSection[iSection][iPoint]); Msg('\n')
        x = float( CrossSection[iSection][iPoint][0] )
        y = float( CrossSection[iSection][iPoint][1] )
        z = float( CrossSection[iSection][iPoint][2] )
        if x<minX: minX = x
        if y<minY: minY = y
        if z<minZ: minZ = z
    #Msg('\n')
doc = FreeCAD.newDocument()
scaleX=1/50.0
scaleY=1/50.0
    drawing=doc.addObject('TechDraw::DrawPage',"Section%s"%iSection)
    template = doc.addObject('TechDraw::DrawSVGTemplate','Template')
    template.Template = templatefile
    drawing.Template = template
    svgSymbol = doc.addObject('TechDraw::DrawViewSymbol','CutSection%s'%iSection)
    drawing.addView(svgSymbol)
    svg = et.Element('svg' )
    svg.set('xmlns',"http://www.w3.org/2000/svg" )
    svg.set('version',"1.1" )
    group = et.Element('g' , fill='black' ,stroke='black')
    group.set('stroke-width' , '0.25')
    svg.append( group )
    data = {}
    oldX =0
    for i in range(0,len(CrossSection[iSection])):
        if i==0:
            z = float( CrossSection[iSection]['p01'][2] )
            data['p'+str(1).zfill(2)] = (0.0 , z)
            oldX = 0.0
        else:
            x1 = float( CrossSection[iSection]['p'+str(i).zfill(2)][0] )
            x2 = float( CrossSection[iSection]['p'+str(i+1).zfill(2)][0] )
            y1 = float( CrossSection[iSection]['p'+str(i).zfill(2)][1] )
            y2 = float( CrossSection[iSection]['p'+str(i+1).zfill(2)][1] )
            z = float( CrossSection[iSection]['p'+str(i+1).zfill(2)][2] )
            dx = x2-x1; dy=y2-y1
            L = sqrt(dx*dx + dy*dy)
            oldX+=L
            data['p'+str(i+1).zfill(2)] = (oldX , z)
    #Msg("Section%s: "%iSection)
    #Msg(data);Msg('\n')
    datum =  ( float(data['p01'][1]) -2 ) *1000
    # Vertical Line
    for i in range(1,len(data)+1):
        x = (float( data[ 'p'+str(i).zfill(2) ][0] ))*1000
        y = (float( data[ 'p'+str(i).zfill(2) ][1] ))*1000
        line1 =  et.Element('line' , x1='%g'%(x*scaleX) ,y1='%g'%(-y*scaleY) ,
                                  x2='%g'%(x*scaleX) ,y2='%g'%( (-datum)*scaleY),
                 stroke= 'blue' )
        group.append(line1)
        line2 =  et.Element('line' , x1='%g'%(x*scaleX) ,y1='%g'%((-datum)*scaleY) ,
                                  x2='%g'%(x*scaleX) ,y2='%g'%( (-datum+750)*scaleY),
                 stroke= 'black' )
        group.append(line2)
    # Contour Line
    for i in range(2,len(data)+1):
        x1 = (float( data[ 'p'+str(i-1).zfill(2) ][0] ))*1000
        y1 = (float( data[ 'p'+str(i-1).zfill(2) ][1] ))*1000
        x2 = (float( data[ 'p'+str(i).zfill(2) ][0] ))*1000
        y2 = (float( data[ 'p'+str(i).zfill(2) ][1] ))*1000
        line1 =  et.Element('line' , x1='%g'%(x1*scaleX) ,y1='%g'%(-y1*scaleY) ,
                                  x2='%g'%(x2*scaleX) ,y2='%g'%(-y2*scaleY),
                 stroke= 'green' )
        group.append(line1)
    y = (float( data[ 'p'+str(i-1).zfill(2) ][1] ))*1000
    text1 = et.Element('text' ,x='0' ,y='%f'%( -y*scaleY-5))
    text1.set('font-size' , str(4))
    text1.text = 'Section%s'%iSection
    group.append(text1)
    x1 = -1000
    x2 = (float( data[ 'p'+str( len(data)  ).zfill(2) ][0] ))*1000 +500
    baseline1 =  et.Element('line' , x1='%g'%(x1*scaleX) ,y1='%g'%(-datum*scaleY) ,
                                  x2='%g'%(x2*scaleX) ,y2='%g'%(-datum*scaleY),
                 stroke= 'black' )
    baseline1.set('stroke-width' , '0.5')
    group.append(baseline1)
    step = 250
    for i in range(0,4):
        y2 = datum-step*i
        baseline2 =  et.Element('line' , x1='%g'%(x1*scaleX) ,y1='%g'%(-y2*scaleY) ,
                     stroke= 'black' )
        baseline2.set('stroke-width' , '0.25')
        group.append(baseline2)
    #Msg(et.tostring(svg)  )
    svgSymbol.Symbol=et.tostring(svg)
chakkree
Post by chakkree »
Add axis and x,y data label to svg string.
import csv
import tempfile
def getBorder(w,h):
</svg>
of.close()
CrossSection = {}
    count = 1
    for row in data:
        if count>1:
            name = row[0]
            id = str1[0]
            pointName = str1[1]
            x  = row[1]
            y  = row[2]
            z  = row[3]
            pointData = (x,y,z)
            else:
        count+=1
# Find Min
minX = 10000000
minY = 10000000
minZ = 10000000
        if x<minX: minX = x
        if y<minY: minY = y
        if z<minZ: minZ = z
    #Msg('\n')
scaleX=1/50.0
scaleY=1/50.0
step = 600.0
    svg.append( group )
    data = {}
    oldX =0
        if i==0:
            oldX = 0.0
        else:
            oldX+=L
    n = int ( round( (datum/10) , 0 ) )
    datum = n*10
    datum -= 2
    datum *=1000
    # Vertical Line
                 stroke= 'blue' )
        group.append(line1)
                                  x2='%g'%(x*scaleX) ,y2='%g'%( (-datum+3*step)*scaleY),
                 stroke= 'black' )
        group.append(line2)
        z = datum-1.5*step
        x_offset = 0.5
        textX = et.Element('text' ,x='%g'%(x*scaleX-x_offset) ,y='%g'%(-(z)*scaleY+5))
        textX.set('font-size' , str(2.5))
        textX.set('text-anchor' , "start" )
        textX.set('fill' , "green" )
        textX.set('stroke' , "none" )
        textX.set('transform' , 'rotate(-90 %g,%g)'%(x*scaleX-x_offset,-z*scaleY+5))
        textX.text ='%.3f'%(x/1000.0)
        group.append(textX)
        z = datum-0.5*step
        textY = et.Element('text' ,x='%g'%(x*scaleX-x_offset) ,y='%g'%(-(z)*scaleY+5))
        textY.set('font-size' , str(2.5))
        textY.set('text-anchor' , "start" )
        textY.set('fill' , "green" )
        textY.set('stroke' , "none" )
        textY.set('transform' , 'rotate(-90 %g,%g)'%(x*scaleX-x_offset,-z*scaleY+5))
        textY.text ='%.3f'%(y/1000.0)
        group.append(textY)
        z = datum-2.25*step
        textAttr = et.Element('text' ,x='%g'%(x*scaleX-x_offset) ,y='%g'%(-(z)*scaleY+5))
        textAttr.set('font-size' , str(2.5))
        textAttr.set('text-anchor' , "start" )
        textAttr.set('fill' , "green" )
        textAttr.set('stroke' , "none" )
        textAttr.set('transform' , 'rotate(-90 %g,%g)'%(x*scaleX-x_offset,-z*scaleY+5))
        textAttr.text ='%s'%('p'+str(i).zfill(2))
        group.append(textAttr)
    # Contour Line
                 stroke= 'green' )
        line1.set('stroke-width' , '0.55')
        group.append(line1)
    text1 = et.Element('text' ,x='0' ,y='%f'%( -y*scaleY-10))
    group.append(text1)
    x1 = -1250
                 stroke= 'black' )
        y2 = datum-step*i
                     stroke= 'black' )
    x = -1200
    z = datum-0.25*step
    textYLabel = et.Element('text' ,x='%g'%(x*scaleX) ,y='%g'%(-(z)*scaleY+5))
    textYLabel.set('font-size' , str(3.5))
    textYLabel.set('text-anchor' , "start" )
    textYLabel.set('fill' , "green" )
    textYLabel.set('stroke' , "none" )
    textYLabel.text ='Y(m)'
    group.append(textYLabel)
    z = datum-1.25*step
    textXLabel = et.Element('text' ,x='%g'%(x*scaleX) ,y='%g'%(-(z)*scaleY+5))
    textXLabel.set('font-size' , str(3.5))
    textXLabel.set('text-anchor' , "start" )
    textXLabel.set('fill' , "green" )
    textXLabel.set('stroke' , "none" )
    textXLabel.text ='X(m)'
    group.append(textXLabel)
    z = datum-2.25*step
    textAttrLabel = et.Element('text' ,x='%g'%(x*scaleX) ,y='%g'%(-(z)*scaleY+5))
    textAttrLabel.set('font-size' , str(3.5))
    textAttrLabel.set('text-anchor' , "start" )
    textAttrLabel.set('fill' , "green" )
    textAttrLabel.set('stroke' , "none" )
    textAttrLabel.text ='Attributes'
    group.append(textAttrLabel)
    # x-ticks
    xMax = float( data[ 'p'+str( len(data)  ).zfill(2) ][0] )
    n = int( round((xMax*10)/25 ,0) )
    z = datum-3*step
    for i in range(0,n+1):
        x = i*2.5 *1000
        if (x/1000)<(xMax+0.75):
            tick = et.Element('line' , x1='%g'%(x*scaleX) ,y1='%g'%(-(z)*scaleY) ,
                                          x2='%g'%(x*scaleX) ,y2='%g'%(-(z)*scaleY+3),
                         stroke= 'black' )
            tick.set('stroke-width' , '0.25')
            group.append(tick)
            text2 = et.Element('text' ,x='%g'%(x*scaleX) ,y='%g'%(-(z)*scaleY+6))
            text2.set('font-size' , str(2.5))
            text2.set('text-anchor' , "middle" )
            text2.text ='%.1f'%(x/1000)
            group.append(text2)
    # y-tick
    #Msg("mixZ=%f\n"%minZ)
    x = -0.25 *1000
    z1 = datum -3*step
    Msg('datum=%f\n'%datum)
    axisY =  et.Element('line' , x1='%g'%(x*scaleX) ,y1='%g'%(-z1*scaleY) ,
                                  x2='%g'%(x*scaleX) ,y2='%g'%(-(z1+4000)*scaleY) ,
                 stroke= 'black' )
    axisY.set('stroke-width' , '0.25')
    group.append(axisY)
    x=-250
    for i in range(1,5):
        z= float(datum)+i*500
                                      x2='%g'%(x*scaleX-3) ,y2='%g'%(-(z)*scaleY),
                     stroke= 'black' )
        group.append(tick)
        text3 = et.Element('text' ,x='%g'%(x*scaleX-4) ,y='%g'%(-(z)*scaleY))
        text3.set('font-size' , str(2.5))
        text3.set('text-anchor' , "end" )
        text3.set('alignment-baseline' , "middle" )
        text3.text ='%.1f'%(z/1000)
        group.append(text3)
        # check dashed line
        if True:
            tickDashed = et.Element('line' , x1='-4' ,y1='%g'%(-(z)*scaleY) ,
                                      x2='%g'%(x2*scaleX) ,y2='%g'%(-(z)*scaleY),
                     stroke= 'blue' )
            tickDashed.set('stroke-width' , '0.18')
            tickDashed.set('stroke-dasharray' , '2 1 0.5 1')
            #tickDashed.set('stroke-dasharray' , '1 0.5 0.25 0.5')
            group.append(tickDashed)
microelly2
chakkree wrote: Wed Jan 03, 2018 3:54 am Add axis and x,y data label to svg string.
Looks good, may I add your script with some parameterisation into my geodat workbench?
chakkree
Post by chakkree »
microelly2 wrote: Wed Jan 03, 2018 9:40 am Looks good, may I add your script with some parameterisation into my geodat workbench?
Thank you. :D
I'm very glad, if this macro is used in geodat wb.
thschrader
Post by thschrader »
I could not resist...CcfOF-wb
chakkree
Post by chakkree »
thschrader wrote: Wed Jan 03, 2018 6:53 pm I could not resist...CcfOF-wb
Wow! Cool! :o
@thschader for posterity, do you mind leaving a step-by-step instruction of how you achieved this thing of awesomeness?
