[Re-Open] [Solved] Sketcher + Expression Engine - 'over-deleting' BUG
Hi, I am not sure i find a problem which is related to expression engine or sketcher only ...https://forum.freecadweb.org/viewtopic.php?f=3&t=24604
I attach an example in which I have a nos. of expression engines (say 12 in the example below) in constraints of a (dependent) sketch linking to a (master) sketch.
Select a few, say 4 of those constraints with expressions to delete (constraints 5 - 8 say) , I found the remaining constraints has more expressions got deleted. In the example attached, there is 1 more expression in a constraint get deleted ( the remaining constraint 5 out of the remaining 1 to 8).
(NOTE - not more constraints got deleted, just 'extra' expression in remaining constraints got deleted, in this example the 'now' constraint 5).
(In my previous file, I get another 4 expression deleted after I delete my selected 4).
Example - 'Dependent' sketch has 12 expression in 12 constraints _
Select 4 constraints (w/ expression), say 5 to 8 to delete _
8 remains. Another 1 expression in 'now' constraint 5 get deleted, blanked
(In my previous file, another 4 expressions get deleted - NOTE: no 'extra' constraint get deleted, just expression(s) disappeared)
FC_0.17_pre on AppImage
OS: Linux
Version: 0.17.12495 (Git)
Build type: None
Hash: a16f5bf9aabaeaf82048d773d1ed3ed4e2f5d704
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
OS: Linux
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
- Test _ Sketch - Expression Engine _ bug __ before.fcstd
- (10.86 KiB) Downloaded 31 times
- Test _ Sketch - Expression Engine _ bug __ after.fcstd
- (11.14 KiB) Downloaded 34 times
Re: Sketcher + Expression Engine - 'over-deleting' BUG
With latest AppImage 12527 git and further test video results, still bugs:-
The following actions results in slightly different bug results - see videos attached
Example sketch + expressions
Deleting 1 edge - w/ 4 constraints & 4 Expression Formulas
Deleting 1 edge w/ 4 constraints w/ 4 Expression Formulas
Deleting directly the 4 selected constraints w/ 4 Expressions
OS: Linux
Version: 0.17.12527 (Git)
Build type: None
Hash: ea4f6f2b2d59911026ff2d8d88c731a7873b612d
Qt version: 4.8.6
OCC version: 7.1.0
- 3 edges in a sketch
- each edge has - 4 constraints & 4 Expressions Formulas
- total 12 expressions in 12 constraints
- Deleting 2nd edge - constraints 5~8 & 4 Expressions
- Original 3rd edge become 2nd edge... etc. -ok
- Result: - 3rd edge's (now is 2nd edge) 4 expressions in 4 constraints got deleted also - Should not be deleted
- Select 2nd edge's - constraints 5~8 w/ 4 Expressions
- Delete the 4 constraints 5~8 (w/ 4 Expressions)
- Result: - 3rd edge's 1st expressions (out of 4) got deleted - Should not be deleted
OS: Linux
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
- (11.14 KiB) Downloaded 30 times
- (10.86 KiB) Downloaded 34 times
I can confirm this in latest master branch. Please register a ticket in the bug tracker, and link to this thread.paullee wrote: ↑Sun Oct 29, 2017 11:29 pm Hi, I am not sure i find a problem which is related to expression engine or sketcher only ...https://forum.freecadweb.org/viewtopic.php?f=3&t=24604
Eivind
eivindkvedalen wrote: ↑Sun Nov 05, 2017 9:06 pmI can confirm this in latest master branch. Please register a ticket in the bug tracker, and link to this thread.paullee wrote: ↑Sun Oct 29, 2017 11:29 pm Hi, I am not sure i find a problem which is related to expression engine or sketcher only ...https://forum.freecadweb.org/viewtopic.php?f=3&t=24604
Eivind
Thanks, first time making a report in the bug tracker. Hope it is done properly.
https://www.freecadweb.org/tracker/view.php?id=3245
Thank you for you report! I've created a fix (link in tracker), and if you have the possibility to compile and test yourself, that would be great. If not, maybe someone else here could test for you?paullee wrote: ↑Mon Nov 06, 2017 5:48 pm Thanks, first time making a report in the bug tracker. Hope it is done properly.
Eivind
Thanks! But can't compile myselfeivindkvedalen wrote: ↑Mon Nov 06, 2017 7:25 pmThank you for you report! I've created a fix (link in tracker), and if you have the possibility to compile and test yourself, that would be great. If not, maybe someone else here could test for you?paullee wrote: ↑Mon Nov 06, 2017 5:48 pm Thanks, first time making a report in the bug tracker. Hope it is done properly.
Eivind
Latest AppImag would have this incorporated?
Nope. You need to manually build it.
@eivindkvedalen sweet!
Thanks again!eivindkvedalen wrote: ↑Thu Nov 09, 2017 7:58 pm
Well, I issued a pull request today... https://github.com/FreeCAD/FreeCAD/pull/1079
Eivind
