Curves workbench
Re: Curves workbench
mfro wrote: Sat Aug 06, 2022 8:03 am After cache update (nothing else done) it said 0.5.4 as well?
The image above was taken after the cache update and checking for updates. However, it was not in latest master, but in 0.21.29393. I then did the update, started FreeCAD, opened AddonManager, clicked on Curves workbench and got this:
Bildschirmfoto 2022-08-06 um 10.08.23.png (57.43 KiB) Viewed 1668 times
In the FreeCAD infos it says still 0.3.0:
OS: macOS 10.16
Version: 0.21.29865 (Git)
Hash: fb5c731847398c5bfbc37468ba851e70860a86d5
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.4.0
  * fcgear
  * fasteners
  * sheetmetal
  * ExplodedAssembly
  * Curves 0.3.0
Syres
Post by Syres »
@chrisb ,the fact that fcgear, Fasteners and Sheetmetal don't have any version numbers next to them indicates either a Mac specific issue or maybe time to clear out all your Addons and reinstall them in maybe groups of three or four. On my self compiled Linux they have been reporting correctly for a good few months and yes they are not all up-to-date but that's for personal reasons while I make sure old files still work.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.21.29966 (Git)
Hash: 3818534cd6bbf78b3a57c946ac73f33650233f6c
Python 3.6.9, Qt 5.9.5, Coin 4.0.0a, Vtk 7.1.1, OCC 7.3.0
  * fasteners 0.3.50
  * Silk 1.0.0
  * Plot 2022.4.17
  * CfdOF 1.16.1
  * BIM 2021.12.0
  * dodo
  * Curves 0.5.4
  * Manipulator 1.4.9
  * fcgear 1.0.0
  * ThreadProfile 1.82.0
  * A2plus 0.4.56a
  * sheetmetal 0.2.56
Syres wrote: Sat Aug 06, 2022 9:05 am time to clear out all your Addons and reinstall them
Good idea, I'll do that later.
Vincent B
Post by Vincent B »
Joincurves mix vertexes: start at 1, 2, 4, ,6 .....34,36.
Even numbers are missing or carry out BOPalgo Self Intersect errors... :o
Curves wb 0.5.2
test_Joincurve.FCStd
(35.58 KiB) Downloaded 36 times
chrisb wrote: Sat Aug 06, 2022 12:14 pm Good idea, I'll do that later.
I have reinstalled all Addon workbenches and it looks all good now. Thanks for the support.
Jolbas
Post by Jolbas »
Chris_G wrote: Wed Aug 03, 2022 5:40 pm The tool fails to produce a closed wire.
I have pushed a fix so that it now returns a compound of edges in such situation (that's better than an broken face).
The last fix works great but sometimes it instead fails with an error:
11:38:44  Traceback (most recent call last):
  File "/Users/bj/Library/Application Support/FreeCAD/Mod/Curves/./freecad/Curves/FlattenFP.py", line 187, in execute
    flat_face = flatten_face(face, obj.InPlace, obj.Size)
  File "/Users/bj/Library/Application Support/FreeCAD/Mod/Curves/./freecad/Curves/FlattenFP.py", line 141, in flatten_face
    nw = Part.Wire(el)
<class 'Part.OCCError'>: BRep_API: command not done
Can we add the workaround with a compound of edges i this case too. Like the following but maybe choosing a more suitable error to raise:
        try:
            nw = Part.Wire(el)
            if not nw.isClosed() or not nw.isValid():
                raise Part.OCCError
        except Part.OCCError:
            FreeCAD.Console.PrintError(f"Wire{i + 1} is not valid. Switching to Compound output.\n")
            build_face = False
            nw = Part.Compound(el)
        else:
            if w.Orientation == "Reversed":
                nw.reverse()
Chris_G
Post by Chris_G »
Would you have a test file please ?
Jolbas
Post by Jolbas »
Yes. I had to remove links to other documents:
nr3test.FCStd
(491.43 KiB) Downloaded 29 times
Chris_G
Post by Chris_G »
Thanks for the file.
I have pushed a fix.
hammax
Post by hammax »
... concerning Sketch_on_Surface some posts before.
A 3D-spiral without any arithmetic algorithm with some rounds.
https://forum.freecadweb.org/viewtopic. ... 87#p617087
If the sketch on surface includes tangent parallel constraints for each turn on the rotating surface
an interesting "twister spiral" is generated as sweep path.
Twister.FCStd
FC.20.1
(57.33 KiB) Downloaded 32 times
