Curves workbench
Re: Curves workbench
I don't manage to use Sketch On Surface in Curves Workbench.
Whatever I do - I tried the two methods on the documentation page https://wiki.freecadweb.org/Curves_SketchOnSurface
I end up with:
' Part.:LineSegment' object has no attribute 'Construction'
which sounds like a Python error. Is it possible for you to upload a minimal working example ?
Using
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.20.25943 (Git) AppImage
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
I end up with:
Using
Qt version: 5.12.9
OCC version: 7.5.2
Is your Curves workbench up-to-date ?
Here is an example file.
- SOS.FCStd
- (10.99 KiB) Downloaded 56 times
Trying to round a closed curve, but as his start begin on the first discretized point, there are still a corner on the curve.
Any tricks?
Any tricks?
- CloseCurve.FCStd
- (12.99 KiB) Downloaded 40 times
First, you should be careful with the Distance method of the Discretize tool, because your setting (0.75mm) puts the last point pretty close to the start point.
The Number method should be preferred if possible to ensure a uniform spacing of the points.
Then, in the Approximate feature, you can use the "Start Offset" property (in the "Range" property group) to move the start point in a straight zone.
This is just a tweak, as this does not ensure smoothness at the join-point.
- CloseCurve-2.FCStd
- (12.45 KiB) Downloaded 42 times
Thanks a lot, moving the start and end point works nice.
I've thank about to work with an half curve as it's symmetrical.
- Half_RoundCurve.FCStd
- (15.2 KiB) Downloaded 45 times
Brown Solid feature icon for a shell I guess?
Why the shell is made instead a green solid?
Maybe because some faces are reversed?
- Capture.JPG (11.99 KiB) Viewed 1892 times
The feature first tries to build a shell from the input faces, then it tries to build a solid from the shell.
Here, the solid creation failed, hence the shell result.
Usually, it comes from a poor contact of the input faces.
