Curves workbench
edwilliams16
Re: Curves workbench
Post by edwilliams16 »
@keithsloan52
doc = App.ActiveDocument
obj = doc.getObject("IsoCurve")
ob, fa = obj.Face
face = getattr(ob.Shape, fa[0])
surf = face.Surface
umin, umax, vmin, vmax = sub.ParameterRange
nu = obj.NumberU
ulist = [i*(umax - umin)/nu + umin for i in range(nu+1)]
nv = obj.NumberV
vlist = [i*(vmax - vmin)/nv + vmin for i in range(nv+1)]
boxLength = 2
cmpd = doc.addObject("Part::Compound","CompoundBoxes")
links = []
for u in ulist:
    for v in vlist:
        base = surf.value(u, v)
        normal = surf.normal(u,v)
        rot = App.Rotation(App.Vector(0,0,1), normal)
        box = Part.makeBox(boxLength, boxLength, boxLength)
        centerpl = App.Placement(-(boxLength/2) * App.Vector(1,1,1), App.Rotation())
        box.Placement = App.Placement(base, rot) * centerpl
        boxdoc = Part.show(box, 'Box')
        links.append(boxdoc)
cmpd.Links = links
doc.recompute()
keithsloan52
Post by keithsloan52 »
edwilliams16 wrote: Sun Dec 04, 2022 9:01 am @keithsloan52
ob, fa = obj.Face
surf = face.Surface
nu = obj.NumberU
nv = obj.NumberV
boxLength = 2
links = []
for u in ulist:
    for v in vlist:
cmpd.Links = links
doc.recompute()
Thanks for the suggestion.
Where is sub being set?
Also look alike don't meet the spec, what needs to be created is an Array of the GDMLObject being passed. In the test case a GDMLBox.
The first item should be a GDMLObject the rest have to be links back to the first but with different position, rotation.
edwilliams16
My mistake sub = face
I missed the substitution and didn’t test. I assume you can turn Part boxes into gdml boxes.
The only addition to code I had already posted was
Surf =face.Surface
keithsloan52
edwilliams16 wrote: Sun Dec 04, 2022 1:12 pm My mistake sub = face
Surf =face.Surface
Already had
surf = face.Surface
It was the sub in the following?
umin, umax, vnin, vmax =sub.ParameterRange
So should it be ?
min, umax, vmin, vmax = surf.ParameterRange
I just tried and it appears not
edwilliams16
umin, umax, vmin, vmax = face.ParameterRange
keithsloan52
Well it runs BUT
Objects are NOT at the intersection of IsoLines
Orientations are not correct.
Least when I used the edges in the IsoCurve, I managed to get the locations correct.
Test-ISO-C.FCMacro
(2.62 KiB) Downloaded 12 times
IsoCurve_Test_After_Macro.FCStd
(195.27 KiB) Downloaded 12 times
edwilliams16
@keithsloan52
I shouldn't make code changes without a computer in front of me... Made an off-by-one error.
However, the orientation issue didn't show in the test case - only when I change the number of contours. I oriented them along the latitude lines.
It isn't clear which orientation the cube on the top should have, so I've omitted it at present.
ob, fa = obj.Face
surf = face.Surface
nu = obj.NumberU - 1
ulist = [i*(umax - umin)/nu + umin for i in range(nu + 1)]
nv = obj.NumberV - 1
vlist = [i*(vmax - vmin)/nv + vmin for i in range(nv + 1)]
boxLength = 2
links = []
for u in ulist:
    for v in vlist[1:]:
        #rot = App.Rotation(App.Vector(0,0,1), normal)
        tangents = surf.tangent(u, v)
        print(f'{tangents[0]} {normal}')
        rot = App.Rotation(tangents[0], App.Vector(), normal, 'ZXY')
cmpd.Links = links
doc.recompute()
Screen Shot 2022-12-04 at 9.06.15 AM.png (31.72 KiB) Viewed 1063 times
edwilliams16
@Chris_G
The NumberU is misleading here. The number of curves is NumberU -1 - ie 5
Screen Shot 2022-12-04 at 9.41.25 AM.png (33.12 KiB) Viewed 1044 times
Screen Shot 2022-12-04 at 9.41.49 AM.png (24.59 KiB) Viewed 1044 times
Chris_G
Post by Chris_G »
edwilliams16 wrote: Sun Dec 04, 2022 7:43 pm The NumberU is misleading here. The number of curves is NumberU -1 - ie 5
Probably because the surface is closed in that direction, so the seam edge is doubled.
edwilliams16
You are right. I exploded the compound, and the seam edge is doubled.
