Curves workbench
Cropduster
Re: Curves workbench
Post by Cropduster »
I have been trying to use interpolate in the Curves WB but it won't work for me: not even a simple set of points from a sketch.
I am using:
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
  * Curves 0.6.1
  * Pyramids-and-Polyhedrons
I was following MangoJelly in the Curves Workbench 16: Boat / Ship building with Interpolate Curves Possible solution? video
Flachy Joe from the FreeCAD github group has suggested Curves Interpolate worked for him! So is this a dependancy issue with me or something in Python I haven't enabled?
Best regards,
BW
Vincent B
Post by Vincent B »
What about to introduce the bezier curve as an option inside interpolated curve?
and arc 3 pts like the line feature?
BezierCurve.FCStd
(12.4 KiB) Downloaded 27 times
kh9k
Post by kh9k »
Dear community members, I try to use interpolate in the Curves WB and get the error:
00:53:13 Running the Python command 'Interpolate' failed:
File "/home/kh8k/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 339, in Activated
source = self.parseSel(s)
File "/home/kh8k/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 322, in parseSel
sen = obj.SubElementNames
'Sketcher.SketchObject' object has no attribute 'SubElementNames'
FreeCad version:
OS: Arch Linux (MATE)
Version: 0.20.29177 (Git) AppImage
Locale: C/Default (C)
* Curves 0.6.1
I'm trying to draw the hull of a boat, being a very beginner CAD user. I have found a discussion on the topic with interpolation and surface creation usage. If you can recommend a better attitude, I will be very grateful.
drmacro
Post by drmacro »
After many attempts, finally a result that passes geometry check. :D
(Though the flat tops aren't circular, as I've never been able to get a valid surface with a circle...)
Snip macro screenshot-05140f.png (56.05 KiB) Viewed 1068 times
FlattopCamel-3.FCStd
(77.59 KiB) Downloaded 26 times
Chris_G
Post by Chris_G »
Cropduster wrote: Sat Nov 26, 2022 4:03 pm I have been trying to use interpolate in the Curves WB but it won't work for me: not even a simple set of points from a sketch.
Best regards,
BW
Unfortunately, without more precise info, I am unable to tell.
Does the report view display any error ?[
Cropduster
Ok, I'm not sure what detail you need, but attached is the file I was using to use the Curves Interpolate feature. Interestingly, the Approximate curve fit works on the attached file, but not Interpolate.
Cropduster
To reiterate, this is the FreeCAD detail:
* Curves 0.6.1
Test-Boat-1.FCStd
(5.17 KiB) Downloaded 25 times
Cropduster
And the report view shows:
15:20:42 Running the Python command 'Interpolate' failed:
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 339, in Activated
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 322, in parseSel
Chris_G
Post by Chris_G »
@Cropduster, @kh9k
Please update CurvesWB, I have pushed a fix.
Cropduster
Thanks Chris_G, operating the Interpolate feature on the same file still did not work, but I notice the error lines are different from previous. So, is this associated with some aspect of Ubuntu I haven't installed/updated?
18:44:20 Running the Python command 'Interpolate' failed:
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 342, in Activated
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 333, in parseSel
verts = obj.Object
'Sketcher.SketchObject' object has no attribute 'Object'
