I am trying Geodata OSM import to ArchSite Terrain and see how it works.
I have OSM Height Import a random location which create Loft of the terrain. I create a Site Object, then the Loft become the Terrain reference. You can see a few screen capture on the progress and with Hi-Res of the high-res towers (the buildings on the lower and left portion area are existing buildings imported by OSM import).
The problem currently I have is I can a random solid trying to 'cut' from this terrain, it seems not working w/ nothing subtracted. I have turned the 'ruled' to Yes in the Loft, then I try turning it off. The result is better, but you can see half of the subtraction become hole.
Anyone done this before and any ideas? Thanks!
FCsrd upload at:-
http://www.filedropper.com/tkoosmmap3te ... erraincut2
Solid for Cutting (Loft is 'Ruled')
Nothing Cut( Loft is 'Ruled')
Cutting 'Half-Done' (Loft is 'Not Ruled')
With Buildings Hi-Res Off
With Buildings Hi-Res On
OS: Linux
Version: 0.17.11111 (Git)
Build type: Unknown
Hash: d3895d03f23ad0454cbcaf3521d21b8bf7b1f7c8
Python version: 2.7.13
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
<Problem re-appear in recent Git> Geodata OSM --> ArchSite Terrain --> Slope Cut Problem
Re: [Solved] Geodata OSM --> ArchSite Terrain --> Slope Cut Problem
Problem Solved.
It turn out Part Extrude do not by default change the base wire (closed to be a face) into solid - need to click a checkbox.
After switch the Solid field in the property view for the Extrusion, the hole is filled!
Hi, i find the same problem appears again in recent git 11210 (Przemof repo for Fedora) - there is piece missing in the cut (see screenshot).
I have a few copy of AppImage and find FreeCAD-0.17.git201703220057.glibc2.17-x86_64.AppImage recompute the ArchSite object without missing piece.
There maybe something wrong somewhere.
FreeCAD file at:-
http://www.filedropper.com/tkoosmmap3te ... nlatestgit
Git using with problem appear again
OS: Linux
Version: 0.17.11210 (Git)
Build type: Unknown
Hash: a0901f57f0347c364e8f6b58069b14eb3fe25b4f
Qt version: 4.8.7
Coin version: 3.1.3
Git without problem
OS: Linux
Version: 0.17.10600 (Git)
Build type: None
Hash: 4d9169faf778e9716fc647fb3fcf46462b5d99a4
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Missing piece in latest Git
Open / Recompute w/o problem in previous Git
FreeCAD file at:-
OS: Linux
Build type: Unknown
Qt version: 4.8.7
Coin version: 3.1.3
Git without problem
OS: Linux
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
