Geodata (Import OSM Map) take forever at 0% / Crash
paullee
Post by paullee »
Hi, I had some times ago installed Geodata probably since on FC0.16 and tested it worked. I am not sure if i use updated to 0.17_pre (through Przemof repo), now I find it is not working.
Removing it and re-installing through the Addon Manager, running 'Import OSM Map' still return error as attached.
Running the Python command 'Import OSM Map' failed:
File "<string>", line 186, in Activated
File "/home/paullee/.FreeCAD/Mod/geodata/geodat/import_osm.py", line 667, in dialog
import geodat.miki as miki
File "/home/paullee/.FreeCAD/Mod/geodata/geodat/miki.py", line 83, in <module>
YourSpecialCreator=Animation.createManager
name 'Animation' is not defined
As hinted else where, Animation was also installed (again),
and
I found i had installed previously the following to make Geodata works, again, double-check they are present.
ImportError: No module named backend_tkagg
dnf install python2-matplotlib-qt4.x86_64
No module named cv2
dnf install opencv-python.x86_64
No module named gdal
dnf install gdal-python.x86_64
Any idea? I am trying to load the terrain again and try Arch Site as shown in Yorik's blog.
Screenshot from 2017-05-13 15-52-44.png (191.36 KiB) Viewed 3095 times
Screenshot from 2017-05-13 09-10-57.png (206.25 KiB) Viewed 3095 times
OS: Linux
Version: 0.17.11034 (Git)
Build type: Unknown
Hash: 36960df73ea8355949ec9421984d498269a238f1
Python version: 2.7.13
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
paullee
Re: Geodata (Import OSM Map) take forever at 0%
Post by paullee »
paullee wrote:Hi, I had some times ago installed Geodata probably since on FC0.16 and tested it worked. I am not sure if i use updated to 0.17_pre (through Przemof repo), now I find it is not working.
Hi, I take out the Przemof 0.17_pre version and re-install back the FC0.16 version.
Added back Geodata and Animation workbench by Macro Addon Manager.
Still return similar error! It used to work. I just do not know what am I missing this time?
Thanks for any idea.
Screenshot from 2017-05-15 21-28-45.png (477.19 KiB) Viewed 3053 times
OS: Linux
Version: 0.16.Unknown
Build type: Unknown
Python version: 2.7.11
Qt version: 4.8.7
Coin version: 3.1.3
paullee
Post by paullee »
Hi, I found Traction61's comment on github (30.3) that a commit left out import animation break the OSM import.
https://github.com/microelly2/geodata/c ... a338e061da
I try add that back in the say.py, now the import OSM dialogue box comes up.
However, after input a coordinate / choose a destination then Run, the progress bar remains at 0% forever - that the point i had before I try removing geodata / animation and reinstalling w/ problem on 13.5.2017.
Anyone using OSM import in Geodata?
Screenshot from 2017-05-17 07-38-41.png (195.1 KiB) Viewed 3017 times
p.s.
I found the original problem may not be related to Fedora and remove it in the title.
microelly2
Post by microelly2 »
There is still a small bug
press the "run values" button a 2nd time :!:
first press loads the data from osm and 2nd press starts the object creation.
paullee
Post by paullee »
microelly2 wrote:There is still a small bug
Thanks, unexpected step!
Unfortunately, probably as the system updated to latest 0.17_pre version through Przemof repo, the OSM import Does Not run at all now! Alert message appear upon 1st 'Run' click and stop! More click have no help.
Any more ideas?
Screenshot from 2017-05-18 00-39-11.png (248.82 KiB) Viewed 2975 times
OS: Linux
Version: 0.17.11090 (Git)
Build type: Unknown
Hash: 4d7554197ee622ac5a4b709aa4205989e54484f3
Qt version: 4.8.7
Coin version: 3.1.3
microelly2
I see you run the "tokyo near tower example"
The error comes because you set the Lenght of the Square down to 0 (Slider is legft,
so there are no data.
I will fix that - start the slider from 0.1
thank you for testing it.
paullee
Post by paullee »
microelly2 wrote:I see you run the "tokyo near tower example"
Thanks agaIn, problem fixed!
Except Yorik's blog, anywhere there is more explanation on each of GeoData functions?
microelly2
paullee wrote:[
I have collected all links on this topic here.
http://freecadbuch.de/doku.php?id=geodat
Most information is in the "Civil Engineering Design functions" thread.
But is realy time to write a more detailed description of the methods. I put it on my schedule. ;)
microelly2 wrote:
paullee wrote:[
:thumbs up:
paullee
Post by paullee »
microelly2 wrote:
paullee wrote:[
Need registration right? A language I don't know :oops:
This thread in freecad right? "Civil Engineering Design functions" https://forum.freecadweb.org/viewtopic. ... 3&start=50.
I ran into a few random pages previously, would read through it then.
Thanks.
Screenshot from 2017-05-19 21-02-08.png (318.45 KiB) Viewed 2887 times
