Spreadsheet -> Drawing, maximum rows
SouthEng
Post by SouthEng »
I have not posted here before as I can normally find an answer within the forum.
I am using the spreadsheet module to create a pinout table for a cable assembly.
The problem I encounter is when I exceed 9 rows... that is on the 10th row the drawing module no longer display's the table.
If I set
"Cell Start" to "A1"
"Cell End" to "D9"
All is good
If I set
"Cell End" to D10"
The table is not longer displayed.
I have tried techDraw and Drawing modules and encounter the problem. Is there something I am doing wrong?
OS: Windows 10
Version: 0.17.10909 (Git)
Hash: eb5c56b50297a03b275846c7bb064ad4aae094da
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 7.1.0
triplus
Re: Spreadsheet -> Drawing, maximum rows
Post by triplus »
Hi @SouthEng.
I can confirm the issue. On FreeCAD 0.16 it is possible to insert:
"Cell End" to D10"
FreeCAD development release on the other hand supports the value D9 as the maximum value. Both TechDraw and Drawing workbenches. In addition if any cell is empty i get:
Error - Could not load Symbol into SVG renderer for Sheet
Therefore you should report the issue on the issue tracker.
Please tag said ticket with the 'spreadsheet' tag. Thx!
SouthEng
Post by SouthEng »
I have been away from my PC and have just got around to checking the post..
Thank you for taking a look I will have a look at the issue tracker and add it if I can.
SouthEng
Post by SouthEng »
Issue created with the spreadsheet tag.
https://www.freecadweb.org/tracker/view.php?id=3010
Cheers
Please add the link to the ticket in this thread and vice-a-versa. Thanks.
