Welder looking to be more efficient using FreeCAD
Montoya88
Post by Montoya88 »
Hi folks,
I run a small fabrication shop, I fab in the daytime and draft in the night time I'm literally a one man crew. I've been using FreeCAD since my join date on this forum, I know enough to get by.
One thing I looking to improve is creating structural shapes ex: square, rectangular, round tubing.
This is my process lets say it's 2" square tubing:
1. Create a cube 2" x 2" x length needed
2. Create another cube minus the wall thickness lets say it's 1/8" so this cube will 1.75" plus length of the first one.
3. Center the cube appropriately.
4.Perform a cut for the Part workbench.
Now I have a square tube, 19 more to go....
Bottom line is there a more efficient way to go about this?
Thanks,
Tim.
Willem
Re: Welder looking to be more efficient using FreeCAD
Post by Willem »
Hi, a lot of steel profiles are in the arch workbech
Schermafdruk van 2017-03-17 09-09-45.png (19.42 KiB) Viewed 3806 times
After placing you can change to the part design workbench for the rest of the job
Montoya88
Post by Montoya88 »
I will definitely give it a try tonight or during my lunch. Thank you.
Montoya88 wrote:I will definitely give it a try tonight or during my lunch. Thank you.
Feel free to document some of your experience for potentially other welders who use FreeCAD.
Montoya88
Post by Montoya88 »
Kunda1 wrote:Feel free to document some of your experience for potentially other welders who use FreeCAD.
Absolutely, I was hoping the subject of this thread will attract other welders/fabricators to help answer similar questions. And hopefully help benefit the developers of FreeCAD with input from my end.
With that being said I would like to use this thread for multiple questions that can't be found in topic search.
Montoya88
Post by Montoya88 »
Willem wrote:Hi, a lot of steel profiles are in the arch workbechSchermafdruk van 2017-03-17 09-09-45.pngAfter placing you can change to the part design workbench for the rest of the job
I would like to know if there is a thread, You Tube video, some resource to learn how to use the arch work bench?
kkremitzki
Post by kkremitzki »
This video was just recently posted in the forums:
https://www.youtube.com/watch?v=F6PIEi33R1g
This is a bit shorter overview: https://www.youtube.com/watch?v=lTDOeHapv_E
Willem
Post by Willem »
Hi, in the book Yorik made is a good arch tutorial starting at page 112. Here the link for a download
https://www.gitbook.com/book/yorikvanha ... al/details
looo
Post by looo »
maybe my little workbench is of any help for your task:
https://github.com/looooo/freecad_frame
example (quite old): (pie-menu is not part of the workbench)
https://vimeo.com/127369120
bejant
Post by bejant »
Montoya88 wrote:One thing I looking to improve is creating structural shapes ex: square, rectangular, round tubing.
I think using the Part WB is more complicated for doing this. Using Part Design instead, only one Sketch is needed and for rectangular Hollow Structural Shapes ("HSS") you only need the height, width, and wall thickness to create a Sketch of the profile (per AISC max outside corner radius is 3x wall thickness). Create a Sketch of the cross-section profile and use Part Design WB > Pad to create the desired length.
Change any of these values to your liking, and save the changed FreeCAD file as a new document. I started with a model of HSS 4 x 3 x 1/4 and it only took a few seconds to change it to HSS 2 x 2 x 1/8 as shown above and attached below.
20170318a-HSS_4x3x0.25.fcstd
(17.04 KiB) Downloaded 79 times
20170318b-HSS_2x2x0.125.fcstd
(17.22 KiB) Downloaded 103 times
OS: Ubuntu 16.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
